AutoDesk Inventor 2015 on Windows 10
Hello Everyone
I have system with Autodesk Inventor 2015 installed on Windows 10.
Following code in VBS is having issues while getting the object (ActiveX component can't create object: 'GetObject')
GetObject(, "Inventor.Application")
I have tried following combination
GetObject(, "Inventor.Application.1")
But not luck.
Any help would be appreciated.
regards
Vivek
TheCADWhisperer
What version of Autodesk Inventor 2015?
bradeneuropeArthur
try this:
dim _InvApp as application
_InvApp = GetObject(, "inventor.application")
but exactly lowercase
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Thank you for prompt suggestion. Since I am trying to code in simple vbs file, this code gives me error. The line
"dim _InvApp as application" gives me issues.
In addition, I changed the UAC setting, checked thr PrgID in regedit and changed name of application name but still I cant hold of that Inventor object.
Is there any way to get the correct PrgID from ROT (Running object table), I can not get any microsoft cerftified x64 application for Win 10 for such.
Professional 2015. Build 159, Release 2015
