Auto Ordinate Dimensions
Message 1 of 22
I'm trying to use iLogic or VBA to add ordinate dimensions to a drawing. This picture explains it.help.png
Here is the code I'm working with so far.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oActiveSheet As Sheet
oActiveSheet = oDrawDoc.ActiveSheet
Dim oIntentCollection As ObjectCollection
oIntentCollection = ThisApplication.TransientObjects.CreateObjectCollection
' Get all the selected drawing curve segments.
Dim oDrawingCurveSegment As DrawingCurveSegment
Dim oDrawingCurve As DrawingCurve
For Each oDrawingCurveSegment In oDrawDoc.SelectSet
    ' Set a reference to the drawing curve.
    oDrawingCurve = oDrawingCurveSegment.Parent
    Dim oDimIntent As GeometryIntent
    oDimIntent = oActiveSheet.CreateGeometryIntent(oDrawingCurve)
    Call oIntentCollection.Add(oDimIntent)
Next
' Set a reference to the view to which the curve belongs.
Dim oDrawingView As DrawingView
oDrawingView = oDrawingCurve.Parent
'  a reference to the ordinate dimensions collection.
Dim oOrdinateDimensions As OrdinateDimensions
oOrdinateDimensions = oActiveSheet.DrawingDimensions.OrdinateDimensions
' Determine the placement point
Dim oPlacementPoint As Point2d
oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(oDrawingView.Left - 5, oDrawingView.Center.Y)
' Create a vertical ordinate set dimension.
Dim oOrdinateSet As OrdinateDimensionSet
oOrdinateSet = OrdinateDimensionSet.AddMember(oIntentCollection)
Any help is appreciated.
Replies (21)
Message 2 of 22
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Can you please provide sample drawing file to analyse drawing curves? please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 22
Here are the part and drawing documents.
Message 4 of 22
Here is what I have now.
Sub Main()
	Dim oTG As TransientGeometry
	oTG = ThisApplication.TransientGeometry
	Dim Entity As DrawingCurveSegment
	Entity = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "Select a kDrawingCurveSegmentFilter")
	oDrawingCurve = Entity.Parent
	Dim oDCE As DrawingCurvesEnumerator
	oDCE = oDrawingView.DrawingCurves()
	Dim oODS As OrdinateDimensions
	oODS = oActiveSheet.DrawingDimensions.OrdinateDimensions
	Dim oOD As OrdinateDimension
	Dim j As Integer
	Dim CurveTypeCount(3) As Integer
	CurveTypeCount(1)=0
	CurveTypeCount(2)=0
	CurveTypeCount(3)=0
	For j = 1 To oDCE.Count()
		oDrawingCurve = oDCE.Item(j)
		Select Case oDrawingCurve.ProjectedCurveType()
			Case 5252 'kCircleCurve2d
				CurveTypeCount(1)=CurveTypeCount(1) + 1
			Case 5253 'kCircularArcCurve2d
				CurveTypeCount(2)=CurveTypeCount(2) + 1
			Case 5251 'kLineSegmentCurve2d
				CurveTypeCount(3)=CurveTypeCount(3) + 1
		End Select
		If oDrawingCurve.ProjectedCurveType() = 5252  Then'kCircleCurve2d
			MessageBox.Show("oDrawingCurve.Type())" & oDrawingCurve.Type(), "kCircleCurve2d") ' kDrawingCurveObject
			oDimIntent = oActiveSheet.CreateGeometryIntent(oDrawingCurve, oDrawingCurve)
			Dim oTextOrigin1 As Point2d
			oTextOrigin1 = oTG.CreatePoint2d(5, 5)
			MessageBox.Show("oTextOrigin1 initialized")
			oOD = oODS.Add( kCenterPointIntent, oTextOrigin1, kHorizontalDimensionType)
			MessageBox.Show("HURRAY IT WORKED!!!!!!!!!!!!")
		End If
	Next
End Sub
 I keep crashing at this line.
 I've tried many combinations for theOrdinateDimensions.Add Method.
' Taken from the inventor API
OrdinateDimensions.Add( Intent As GeometryIntent, TextOrigin As Point2d, DimensionType As DimensionTypeEnum, [DimensionStyle] As Variant, [Layer] As Variant ) As OrdinateDimension
Message 5 of 22
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Try below iLogic code to automate ordinate dimension.
Public Sub Main()
  ' Set a reference to the drawing document.
  ' This assumes a drawing document is active.
  ' Set a reference to the active sheet.
  '   a reference to the drawing curve segment.
  ' This assumes that a linear drawing curve is selected.
    oDrawingCurveSegment = ThisApplication.CommandManager.Pick(kDrawingCurveSegmentFilter, "Select start line to start ordinate dimension")
  '   a reference to the drawing curve.
  If Not oDrawingCurve.CurveType = kLineSegmentCurve Then
    MsgBox ("A linear curve should be selected for this sample.")
    Exit Sub
  End If
  ' Create point intents to anchor the dimension to.
    oDimIntent = oActiveSheet.CreateGeometryIntent(oDrawingCurve, kEndPointIntent)
  '   a reference to the view to which the curve belongs.
  ' If origin indicator has not been already created, create it first.
  If Not oDrawingView.HasOriginIndicator Then
    ' The indicator will be located at the start point of the selected curve.
    oDrawingView.CreateOriginIndicator (oDimIntent)
  End If
  Dim oTextOrigin  As Point2d
  Dim DimType As DimensionTypeEnum
  ' Selected curve is vertical or at an angle.
  DimType = kHorizontalDimensionType
  '   the text points for the 2 dimensions.
    oTextOrigin = ThisApplication.TransientGeometry.CreatePoint2d(oDrawingView.Left + 2, oDrawingCurve.StartPoint.Y)
  ' Create the first ordinate dimension.
  Call oOrdinateDimensions.Add(oDimIntent, oTextOrigin, DimType)
  For Each oDrawingCurve In oDrawingView.DrawingCurves
    If oDrawingCurve.CurveType = kCircleCurve Then
        Dim oIntent As GeometryIntent
          oIntent = oActiveSheet.CreateGeometryIntent(oDrawingCurve, kCenterPointIntent)
        Dim origin As Point2d
          origin = ThisApplication.TransientGeometry.CreatePoint2d(oDrawingView.Left + 2, oDrawingCurve.CenterPoint.Y)
        Call oOrdinateDimensions.Add(oIntent, origin, DimType)
    End If
  Next
    oDrawingCurveSegment = ThisApplication.CommandManager.Pick(kDrawingCurveSegmentFilter, "Select end line to complete ordinate dimension")
    Exit Sub
  End If
End Sub
On running above code, it prompts to select 2 lines as shown below.
On successful completion of code, Result of iLogic code is shown as above.
Note: iLogic code is customized for current drawing.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 6 of 22
When I run the rule, I get the error code,
  • The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
and under More Info.
  • System.ArgumentException: The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG)
  • at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
  • at Inventor.CommandManager.Pick(SelectionFilterEnum Filter, String PromptText)
  • at LmiRuleScript.Main()
  • at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
  • at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Neither prompt comes up. I am running Inventor 2017.
Changing kDrawingCurveSegmentFilter to SelectionFilterEnum.kDrawingCurveSegmentFilter fixed the previous issue.
Now selecting the bottom line results in the  error message "A linear curve should be selected for this sample."
Message 7 of 22
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Try below VBA code instead of iLogic code (working procedure is same). iLogic code is wokring in Inventor 2019 but throwing exception on creating origin indicator in Inventor 2017.
Public Sub Main()
    Set oDrawDoc = ThisApplication.ActiveDocument
    Set oActiveSheet = oDrawDoc.ActiveSheet
    Set oDrawingCurveSegment = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "Select start line to start ordinate dimension")
    Set oDrawingCurve = oDrawingCurveSegment.Parent
    If Not oDrawingCurve.CurveType = CurveTypeEnum.kLineSegmentCurve Then
    Exit Sub
    End If
    Set oDimIntent = oActiveSheet.CreateGeometryIntent(oDrawingCurve, kEndPointIntent)
    Set oDrawingView = oDrawingCurve.Parent
        Call oDrawingView.CreateOriginIndicator(oDimIntent)
    End If
    Set oOrdinateDimensions = oActiveSheet.DrawingDimensions.OrdinateDimensions
    DimType = DimensionTypeEnum.kHorizontalDimensionType
    Set oTextOrigin = ThisApplication.TransientGeometry.CreatePoint2d(oDrawingView.Left + 2, oDrawingCurve.StartPoint.Y)
    Dim oOrdinateDimension1 As OrdinateDimension
    Set oOrdinateDimension1 = oOrdinateDimensions.Add(oDimIntent, oTextOrigin, DimType)
        Set oIntent = oActiveSheet.CreateGeometryIntent(oDrawingCurve, kCenterPointIntent)
        Set origin = ThisApplication.TransientGeometry.CreatePoint2d(oDrawingView.Left + 2, oDrawingCurve.CenterPoint.Y)
    End If
    Next
    Set oDrawingCurveSegment = ThisApplication.CommandManager.Pick(kDrawingCurveSegmentFilter, "Select end line to complete ordinate dimension")
        Exit Sub
    End If
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 8 of 22
This works! Thank you very much for your help.
Its interesting how the same code will only work in one environment. The three options between the iLogic rule environment, the iLogic rule environment with Straight VB code selected and the VBA editor environment.
So the iLogic environment uses VB.NET and the VBA editor uses VBA?
Message 9 of 22
it is possible to drop the command and select a line automatically because it is always the same. Or place zero and start from there? I have to place the dimensions on some supports. those coming from a configurator so the number and the distances are different
Point A is always the same plane and is always in the same place on the drawing
Point B is always the same part so can I use a work surface or a work point in my part?
is this possible I am completely stuck on this problem 🙂
Message 10 of 22
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous
Can you please share non confidential Inventor drawing to check the feasibility?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 11 of 22
hello
attached the modified code without the command. Now it is only the intention to replace the centers with faces with a certain to atribute ... But I get stuck on the 2nd part from  the  for instruction
thank you
Message 12 of 22
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
It looks like old drawing is attached in the previous post.
Can you please provide non confidential drawing with support?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 13 of 22
no I have changed the code but use it as a test. If you run rule1 you will see ... but I cannot upload my Assembly i can only upload 2 files...
Message 14 of 22
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Actually, iLogic code is customized to work on particular drawing. If you can provide non confidential full assembly, I can investigate on that.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 15 of 22
Best
in attachment you can see the assembly. I made an example of how it should be on the 2d drawing
thanks
Message 16 of 22
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Sorry for late reply,
Attachment downloaded and investigated, it is found that it is series of assembly origin and subsequent origins are belongs to parts. So, ordinate dimension is required for this series of origins.
Can you please confirm the requirement to implement the code?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 17 of 22
Yes the intention is that the origin starts at the left corner and between the 2 corners it is the same part and I always need the origin of these parts.
thank you very much
Message 18 of 22
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Try below VBA code to create ordinate dimension.On running code, ask to select a line to find out occurrence in assembly document as shown in below image.
Public Sub Main()
    Dim oDoc As Document
    Set oDoc = oActiveSheet.DrawingViews.Item(1).ReferencedDocumentDescriptor.ReferencedDocument
    If oDoc.DocumentType = kAssemblyDocumentObject Then
        Set oDrawingCurveSegment = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "Select start line to find occurrence")
        Dim oReferDef As AssemblyComponentDefinition
        Set oReferDef = oDoc.ComponentDefinition
        Dim pt As WorkPoint
        Set pt = oReferDef.WorkPoints.Item(1)
        Call oActiveSheet.DrawingViews.Item(1).SetIncludeStatus(pt, True)
            Exit Sub
        End If
        Dim oCenterMark As Centermark
        Set oCenterMark = oActiveSheet.Centermarks.Item(oActiveSheet.Centermarks.Count)
        Set oDimIntent = oActiveSheet.CreateGeometryIntent(oCenterMark, kCenterPointIntent)
        End If
        DimType = DimensionTypeEnum.kVerticalDimensionType
        Set oTextOrigin = ThisApplication.TransientGeometry.CreatePoint2d(oCenterMark.Position.X, oCenterMark.Position.Y - 2)
        Dim LArray() As String
        LArray = Split(oDrawingCurve.ModelGeometry.ContainingOccurrence.Name, ":")
        Dim occ As ComponentOccurrence
        For Each occ In oReferDef.Occurrences
            Dim occName() As String
            occName = Split(occ.Name, ":")
            If occName(0) = LArray(0) Then
                Set pt = occ.Definition.WorkPoints.Item(1)
                Dim oProxy As WorkPointProxy
                Call occ.CreateGeometryProxy(pt, oProxy)
                Call oActiveSheet.DrawingViews.Item(1).SetIncludeStatus(oProxy, True)
                Set oIntent = oActiveSheet.CreateGeometryIntent(oCenterMark, kCenterPointIntent)
                Set origin = ThisApplication.TransientGeometry.CreatePoint2d(oCenterMark.Position.X, oCenterMark.Position.Y - 2)
            End If
        Next
    Else
        MsgBox ("Referenced document is not an assembly document")
    End If
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 19 of 22
Best
thank you very much I have adjusted the code so that it now works with atributes and I no longer have to select the line. Thanks again 🙂
Message 20 of 22
andygleis
Is their an updated version of this code? I keep getting an error with it
