Change Sketch Symbol by Ilogic
yohansampaio
yohansampaio
I have a question about whether it's possible to change the text within a sketch symbol that exists in an existing detail.
In this case, I have a sketch symbol called "PA" with the text "Perfil Alto" inside.
I need a rule that changes the text from Perfil Alto to High Profile.
However, within the sketch symbol, the text is inserted as the requested input. (Property field: "OBSERVATIONS", VALUE: "PERFIL ALTO").
Can anyone help me?
This code below is not working.
' Obter o documento de desenho atual
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet = oDrawDoc.Sheets(1)
' Percorrer todos os símbolos da folha
Dim oSymbol
For Each oSymbol In oSheet.SketchedSymbols
    If oSymbol.Definition.Name = "PA" Then
        ' Substitui o valor do prompt chamado "OBSERVAÇÕES"
        oSymbol.SetPromptResultText("OBSERVAÇÕES", "HIGH PROFILE")
Next
Andrii_Humeniuk
Hi @yohansampaio .
To get and edit Property Field you need to use TextBoxes object. Below you can see an example of editing text according to your case.
For Each oSymbol As SketchedSymbol In oSheet.SketchedSymbols
		Dim oTextBoxes As TextBoxes = oSymbol.Definition.Sketch.TextBoxes
		For Each oTBox As Inventor.TextBox In oTextBoxes
			If Not oTBox.Text = "OBSERVAÇÕES" Then Continue For
			If oSymbol.GetResultText(oTBox) = "PERFIL ALTO" Then
				oSymbol.SetPromptResultText(oTBox, "HIGH PROFILE")
				Exit For
		Next
Next
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
yohansampaio
Thank you so much @Andrii_Humeniuk for your help.
It worked , and now I can adapt it to other situations.
