Associatvity state change event?
Cris-Ideas
Advisor Advisor
Message 1 of 17
Cris-Ideas
I was almost there with my code.
But run on to a serious obstacle.
I need to catch when associativity setting for componet's DVR is changed.
I did't find any event that would indicate this.
Does anyone know if there is such an event?
Cris.
Cris,
https://simply.engineering
Replies (16)
Message 2 of 17
bradeneuropeArthur
Try this command via the manager:
"PartAdaptiveFeatureCtxCmd"
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 17
bradeneuropeArthur
Public WithEvents UIE As Inventor.UserInputEvents
Try
         UIE = _InvApp.CommandManager.UserInputEvents
Catch ex As Exception
End Try
Private Sub UIE_OnActivateCommand(CommandName As String, Context As NameValueMap) Handles UIE.OnActivateCommand
        MsgBox(CommandName)
if CommandName = "PartAdaptiveFeatureCtxCmd" then
'DO THIS>>>>>>
end if
    End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 4 of 17
Cris-Ideas
Edited:
Sorry you did already.
Thread did not update.
will look in to it
@bradeneuropeArthur
Thanks for advice.
But I need much wider context as I am not able to understand what exactly and where and how should I do.
Could you provide me with some more detail directions or example maybe?
Cris
Cris,
Message 5 of 17
bradeneuropeArthur
Don't you understand what and how to program this is your add in?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 17
Cris-Ideas
Ok,
I may be able to catch activation of the command window.
But how can I than find out if after this command is done component is associative or not?
I am looking to find a way to detect when associativity state of DVR of the component changes form True to False.
other direction works fine (so I am able to detect when it is changed from False to True).
Cris.
Cris,
Message 7 of 17
bradeneuropeArthur
let's take a look...
keep reading...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 17
Cris-Ideas
Well it is my add-inn, and I can program only a little bit. 😉
So what it is suppos to do is:
Manage visibility of the component to get rid of the annoying thing that is putting components in Master DVR after they are set associative turned off and on again.
So far I was able to successfully get this done using windows form application. But components must be turned off by clicking button on the form.
What I would like to get is to link to the visibility event of the component by ComponentOccurecneOnChange Event, but there I have run on to the problem of bug in the event.
When associativity is changed from false to true it is properly indicated in during the Event. But when it is changed from True to False it is wrong as it is indicated as False before and after Event.
Also when associative component is being turned off there is a message window informing that associativity will be removed. And this window does not bring up ComponentOccurenceOnChange Event at all, and associative state if obviously changed.
So I am looking for a way to monitor associativity state of the componentoccurence DVR in some other way, that would allow me to know whether  component was set to be associative the moment user chooses to switch it off.
Cris.
Cris,
Message 9 of 17
bradeneuropeArthur
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.ActiveDocument
MsgBox oPartDoc.ModelingSettings.AdaptivelyUsedInAssembly
What do you mean with "Master DVR"
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 17
bradeneuropeArthur
Sorry completely wrong what I understood.
Sorry from my side.
I read It wrong
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 17
bradeneuropeArthur
Public Sub main()
Dim a As AssemblyDocument
Set a = ThisApplication.ActiveDocument
Dim b As AssemblyComponentDefinition
Set b = a.ComponentDefinition
Dim occ As ComponentOccurrence
For Each occ In b.Occurrences
MsgBox occ.IsAssociativeToDesignViewRepresentation
Next
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 17
Cris-Ideas
Yes this is the property.
But I am not looking for a way to read it but to monitor its state and defectively to catch all changes in its state while user works in the assembly.
Or if not possible than at least state just before user sets component's visibility state to off.
there is ComponentOccurrenceOnChahge event but it indicates IsAssociative.. property value not correctly in case of the Event that is raised when visibility is switched off.
Also there is this dialogue window I mentioned which does not rise this event at all, but in the same time it changes IsAssociative... property setting.
Cris.
Cris,
Message 13 of 17
bradeneuropeArthur
Hope this is what ypu need:
Public WithEvents AE As Inventor.AssemblyEvents
AE = _InvApp.AssemblyEvents
Private Sub AE_OnOccurrenceChange(DocumentObject As _AssemblyDocument, Occurrence As ComponentOccurrence, BeforeOrAfter As EventTimingEnum, Context As NameValueMap, ByRef HandlingCode As HandlingCodeEnum) Handles AE.OnOccurrenceChange
        MsgBox(Occurrence.IsAssociativeToDesignViewRepresentation)
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 17
Cris-Ideas
I have tried this approach in the begging, but it does not work.
Do you have any other idea?
link to download video in better resolution https://autode.sk/2MSyOAA
Cris.
Cris,
Message 15 of 17
bradeneuropeArthur
hi,
If the DVR changes back to "Master" when the checkmark is removed, the Value becomes empty.
So:
        MsgBox(Occurrence.ActiveDesignViewRepresentation)
if Occurrence.ActiveDesignViewRepresentation ="" then
'Do this.....
else
'Do this.....
end if End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 16 of 17
Cris-Ideas
Will investigate this way.
Cris.
Cris,
Message 17 of 17
Cris-Ideas
tried latest suggestion.
Unfortunately same problem as before.
In case I remove associativity before and after events indicate IsAssociative=False and ActiveDesignViewRepresentation = ""
This however works when I assign associativity.
Earlier you suggested catching dialogue window.
In case of command windows is there an event raised when dialogue is closed (OK, CANCL) indicating settings of the command?
Cris.
Cris.
Cris,
