Assigning the ilogic parameter
Rogov_Sergey
Rogov_Sergey
There is a rule that changes the BaseQuantity of parts for each frame Assembly. How to make a parameter from the part "G_L" or "length" assigned to the note or added to the name at the end.
Sub Main()
  doc = ThisDoc.Document
    CompOccurs = doc.ComponentDefinition.Occurrences
    For Each Occur In CompOccurs
      OccurDoc=Occur.Definition.Document
          If OccurDoc.DocumentType<>kPartDocumentObject Then Continue For
           If Occur.BOMStructure=BOMStructureEnum.kPurchasedBOMStructure Then Continue For
                Call OccurDoc.ComponentDefinition.BOMQuantity.SetBaseQuantity(BOMQuantityTypeEnum.kEachBOMQuantity)
			iProperties.Value("Project", "Part Number")=ThisDoc.FileName(False)
    Next
End Sub
Находите сообщения полезными? Поставьте Нравится (Like) этим сообщениям!
На ваш вопрос успешно ответили? Нажмите кнопку 'Утвердить решение'
Рогов Сергей/ Rogov Sergey
Инженер-конструктор
JhoelForshav
Hi @Rogov_Sergey
I don't fully understand what you want the code to do. Is it some property that should contain the length? Or maybe the occurrence name in the browser tree? Could you do it manually and take a screenshot of the result to show me? 🙂
Rogov_Sergey
Every part has the option to "G_L" need to have it on all the parts went in the comments.
The rule is executed from the frame.
Инженер-конструктор
JhoelForshav
@Rogov_Sergey
Something like this? 🙂
Sub Main()
           If Occur.BOMStructure = BOMStructureEnum.kPurchasedBOMStructure Then Continue For
			iProperties.Value("Project", "Part Number") = ThisDoc.FileName(False) 'What's the purpose of this line?
			Try
			Dim oUM As UnitsOfMeasure = OccurDoc.UnitsOfMeasure
			OccurDoc.PropertySets.Item("Inventor Summary Information").Item("Comments").Value = _
			"Length: " & oUM.GetStringFromValue(OccurDoc.ComponentDefinition.Parameters.UserParameters.Item("G_L").Value _
			, oUM.LengthUnits)
			Catch
				'The Frame Reference model doesn't contain the parameter
			End Try
    Next
End Sub
JhoelForshav
It could be simplified with the ilogic functionality for properties and parameters.
Sub Main()
	OccurDoc = Occur.Definition.Document
	If OccurDoc.DocumentType <> kPartDocumentObject Then Continue For
	iProperties.Value(Occur.Name ,"Project", "Part Number") = ThisDoc.FileName(False)
	Try
		iProperties.Value(Occur.Name ,"Summary", "Comments") = _
		"Length: " & oUM.GetStringFromValue(Parameter.Param(Occur.Name, "G_L").Value, oUM.LengthUnits)
		MsgBox(Parameter(Occur.Name, "G_L"))
	Catch
	End Try
Next
End Sub
I also changed the setting of part number to affect the occurrence. I assume that's what you want since it is inside the loop... It still changes to the frame assemblys filename though. Let me know what it's supposed to do 🙂
Rogov_Sergey
Thank you, you were very helpful. Last question a round the value to one character?
Инженер-конструктор
JhoelForshav
@Rogov_Sergey
You can set the length precision like this:
Sub Main()
	Try
		oUM.LengthDisplayPrecision = 1 'Set Length precision
	Catch
	End Try
Next
End Sub
