Assigning a material to an assembly for BOM purposes
Hi!
I've been looking high and low on these forums and by googling, but have not found a solution to my issue.
You are my only hope.
I'm trying to assign materials to parts in a assembly, based on the part name.
The materials "Wood" and "Divinycell H60" is already present in the "local" document material assets in the assembly.
When checking the first occurence with "lag" in the part name, Inventor crashes without any given reason at the line:
oc.Definition.Material = asm.Materials.Item("Divinycell H60")
Does anyone have a good solution for me?
Dim doc As Document
Set doc = ThisApplication.ActiveDocument
If doc.DocumentType = kAssemblyDocumentObject Then
   'nothing
Else
    Call MsgBox("Must be an assembly document", vbOKOnly, "Error")
    Exit Sub
Dim asm As AssemblyDocument
Set asm = ThisApplication.ActiveDocument
Dim libasset As MaterialAsset
Dim oc As ComponentOccurrence
For Each oc In asm.ComponentDefinition.Occurrences
    If InStr(1, oc.name, "kasse", vbTextCompare) Then
        oc.Definition.Material = asm.Materials.Item("Wood")
    If InStr(1, oc.name, "skott", vbTextCompare) Then
    If InStr(1, oc.name, "lag", vbTextCompare) Then
Next
End Sub
bradeneuropeArthur
Turn your assembly first into a "weldment assembly".
"Normal Assemblies" don't have material.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
