- Mute
- Permalink
- Report
Basically, I'm attempting is to assign surface bodies to the phantom layer, for drawing views of parts.
We use surfaces quite a bit. Typically they are derived into a part for construction purposes.
There are times when we need the surfaces visible in the drawings, for reference.
The issue is, in the drawing environment surfaces are viewed as visible edges.
There is not a separate object default for surface edges. They are treated just like solids.
In our case, if we have surfaces in a part we need them to appear phantom in the views.
Currently, we manually find the surface body in the browser, select as edges, then change the layer to Phantom.
What I need is to automate that process...
Find the surface bodies in drawing views and change them to the Phantom layer.
I have found many examples of code to change layers and select bodies. I haven't found anything close to get to what I need.
It sounds simple, and probably is for the ilogic gurus.
Any assistance or direction would be greatly appreciated.
Thanks in advance,
Dewayne
Inventor Pro 2023
Vault Pro 2023
