AssemblyConstraints - isolate parts
GeorgK
Advisor Advisor
GeorgK
Hello together,
how could I isolate the parts to a given constraint?
Thank you
Georg
JoAnn_Hogan
In your model browser > expand the relationships folder > Go to the Contraint you want to isolate and select "Isolate Components"
Please let me know if this works
If this post solved your issue please mark as solved and Kudos are always welcome 😃
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
GeorgK
I am looking for a VB.Net solution 🙂
philippe.leefsma
You probably mean isolate the occurrences to be accurate ... the command is doing nothing more than changing the visibility of affected occurrences by a certain constraint. Each constraint will return the affected occurrences, for example:
 - MateConstraint.AffectedOccurrenceOne Property
 - MateConstraint.AffectedOccurrenceTwo Property
To set the occurrence visibility, use ComponentOccurrence.Visible = false.
I hope it helps.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
