2014 Inventor reflections - Can't see
Message 1 of 14
I am using 2014 Inventor and it used to be that I could see the reflections when using chrome or another reflective color. If I create a ball I can see it but otherwise I can not see it. Also when creating a .idw drawing it used to show the reflections on the drawing. Is it possible to do this in 2014?
I am at a loss trying to figure it out.
Replies (13)
Message 2 of 14
JoAnn_Hogan
Go to the big I in the corner (Application Menu) > Options > Colour Tab > Reflection Environment > And choose for eg Parking lot.
Please let me know if this works. You can definately see reflections in Inventor 2014
If this post solved your issue please mark as solved and Kudos are always welcome 😃
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
Message 3 of 14
Yes, I can see the reflection as long as I create a ball - I have a different picture other than the parking lot but I can definately see it on the ball, Clear as day. The problem I am having is seeing it on anything else, Say a box or something with flat sides. I know in 11 or 12 I could see it easily but the last couple of revisions - No luck. Also used to be able to see the reflections when I printed out the .idw prints and now it just looks grey, No reflection.
Message 4 of 14
JoAnn_Hogan
Are you using a default picture or one of your own?
Jo - Ann
Message 5 of 14
yes. Like I said, For some reason it shows up on the ball but nothing else. I used the same picture on older versions of Inventor with no issues.
Message 6 of 14
JoAnn_Hogan
  • Do you have all the latest service packs installed and if so are they installed correctly in the correct sequence?
  • You could also try updating your display drivers through your windows manage console
  • If all else fails try a repair through your control panel if that still doesn't work, Uninstall and reinstall
Jo - Ann
Message 7 of 14
I believe we have all of the service packs installed. This has been a issue with 2013 for me as well. I don't remember for sure if 2012 worked or not.
Message 8 of 14
JoAnn_Hogan
Are you by any chance using the Chrome.dds file?
Jo - Ann
Message 9 of 14
I changed it back to the parking lot picture & it works as it should. Aparently my picture file is not working for some reason. It is odd that it works on a ball but nothing else.
I will try a different picture.
Message 10 of 14
JoAnn_Hogan
I am glad it works now. Please mark my post as solved and do not hessitate to contact me if you get stuck again 😃
Jo - Ann
Message 11 of 14
one more question, What type of file can I replace the parking lot with so it works corectly?
Message 12 of 14
JoAnn_Hogan
There are many converters online. Maybe have a look at this one: http://www.easy2convert.com/jpg2dds/
Basically you have to convert a normal picture to a .dds file (Cube Map Image)
Jo - Ann
Message 13 of 14
Is there any other format that will work other than the DDS? - The reason I ask is I used both a JPG & PNG and they both work as a reflection on the ball but nothing else.
Message 14 of 14
JoAnn_Hogan
JPG and PNG would work but the reason for converting the image to .dds is because it is actually making a sphere so you can see it from any angle, where as a JPG/PNG is just a flat surface. Please see the attachment.
Jo - Ann
