Assembly pattern element appearance overrides
blandb
Mentor Mentor
Message 1 of 20
blandb
Good afternoon. Please look at the code below, I have highlighted something in RED that I was hoping someone could assist with.  I have an assembly that I am using a multi-value set list to set basic names of paint to use. Then I have a Select case statement that states if I choose a selected basic color, then try and check to see if certain components exist, if so paint them the specific color. All works ok because my others rules that build this assembly place the components, then paints them, and then patterns the components. Where it fails, is when I just want to change the color without reconfiguring something. It will change all of the main parent elements of the pattern, but not the second, third, 4th and so on. Why not just select the entire pattern and change the color you might ask? Well, there are bolts, I dont want the bolts painted, just the main parts. So that is why I cannot just paint the entire pattern.
I also cannot just paint the main components at the part level because these are standard parts that can be any finish. I am just painting them the main 10 colors we have. We dont have a dedicated part number for the colored version of the component, so I am applying Assembly based appearance overrides at the assembly. As you can see in the image, when this is first configured, the post and panels are the correct color. But if I want to just change a color, now it only changes the parent component because i am not doing the entire pattern. Same concept if you place an part at the assembly level, color override it, then pattern it they will all be that color. But now, change the first element color to something else, all others stay as the original color. Hope this all makes sense 🙂
Dim oDoc As AssemblyDocument
Dim oPattern As OccurrencePattern
Dim oElements As OccurrencePatternElements
Dim oElement As OccurrencePatternElement
oDoc = ThisApplication.ActiveDocument
oPattern = oDoc.ComponentDefinition.OccurrencePatterns.Item("whatever my pattern name is")
oElements = oPattern.OccurrencePatternElements
Select Case PAINT
Case "MED. BRONZE"
Try 'try to set the component state
If Component.IsActive("RIGHT SIDE END POST") = True Then
Component.Color("RIGHT SIDE END POST") = "FNSH000510 (38/60060)"
End If
Catch 'catch error and assume the part does not exist
End Try
If Component.IsActive("RIGHT SIDE END POST PATTERN") = True Then
Component.Color("RIGHT SIDE END POST PATTERN ELEMENTS excluding fasteners") = "FNSH000510 (38/60060)"
End If
End Try
case "SILVER"
"repeat info, just different color"
end Select
Autodesk Certified Professional
Replies (19)
Message 2 of 20
A.Acheson
@blandb
My thoughts, untested and perhaps barking up a tree, would be to change the colour of all the patterns and then set the fasteners back to there default colour . I don't think there is a catch all for fasteners but they could be found either directly through part number or the occurance contains”Washer”,”Bolt”,Nut”, otherwise if you have there placement info like shown in the link that would work as well.
https://forums.autodesk.com/t5/inventor-customization/using-ilogic-to-enable-or-disable-hardware-in-...
Perhaps there is a way to isolate the fasteners and not include it in the colour override?
I can only assume if you were to repattern the original assembly after paint change this would have an effect on the drawing losing annotation references as the pattern would disappear and reappear ?
Hope this helps
Regards
Alan
Message 3 of 20
_dscholtes_
@A.Acheson wrote:
@blandb
When fasteners are placed from ContentCenter, the <component definition>.IsContentMember property = True. So you could process all elements, check for this property and skip coloring them.
Another option could be to check if the fastener is defined as a purchase part, by looking at the <component definition>.BOMStructure = kPurchasedBOMStructure. Success depending on how you've defined your fasteners and components.
Message 4 of 20
dutt.thakar
@blandb
Are you looking for something like this? Make sure you change your pattern and appearance name before you test.
Dim oProjectMgr As DesignProjectManager = ThisApplication.DesignProjectManager
Dim CCPath As String = oProjectMgr.ActiveDesignProject.ContentCenterPath
oPattern = oDoc.ComponentDefinition.OccurrencePatterns.Item("Your Pattern Name")
If Component.IsActive("Your Pattern Name") = True Then
	For Each oElement In oElements
		For Each oOcc As ComponentOccurrence In oElement.Occurrences
			If oOcc.Definition.Document.FullFileName.Contains(CCPath) = False
      				 Component.Color(oOcc.Name) = "Appearance Name"
			End If
		Next
	Next
End If
Hope this will be helpful.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
Message 5 of 20
blandb
@dutt.thakar
Thank you! Once I figured out where to place this, it worked as expected.
Thanks again!
Message 6 of 20
_dscholtes_
@dutt.thakar wrote:
@blandb
can be replaced with
If oOcc.Definition.IsContentMember = False
which is shorter, maybe a tiny bit faster and doesn't require the declarations of both oProjectMgr and CCPath
Message 7 of 20
blandb
One question, if I have (3) separate patterns that I have to do this with, can I add the names in the "oPattern" section like this:
oPattern = oDoc.ComponentDefinition.OccurrencePatterns.Item("Your Pattern Name", "Pattern Name 2", "Pattern Name 3")
or would I have to make 3 separate lines like this:
oPattern1 = oDoc.ComponentDefinition.OccurrencePatterns.Item("Your Pattern Name 1")
oElements1 = oPattern1.OccurrencesPatternElements
oPattern2 = oDoc.ComponentDefinition.OccurrencePatterns.Item("Your Pattern Name 2")
oElements2 = oPattern2.OccurrencesPatternElements
--------------same for the third pattern------------------
Message 8 of 20
blandb
tried this, but I get an error message
Message 9 of 20
_dscholtes_
Sorry, I have made a mistake. My earlier post is incorrect. The 'IsContentMember' property is only available from the <part document>.ComponentDefinition, not from an <Occurrence>.Definition. Same goes for the 'BOMStructure' property.
That means the solution from dutt.thakar should be used unmodified.
Regarding your other question, you should have three separate lines.
Message 10 of 20
blandb
Does just the oPattern need to have (3) instances, or does the oElement and oElements need 3 lines as well.
Sorry, I'm not a programmer..lol
Message 11 of 20
dutt.thakar
@blandb
If you only have three patterns and you want to do the same operation in all of them you do not need to define three times. You can use For Each loop.
As an example :
For Each oPattern In oDef.OccurrencePatterns
and then the same code with little modifications where you will not have to specify explicitly pattern name because you are iterating to all patterns and not targeting a specific pattern.
Try and see if this is helpful or reply if you still struggle and I will be able to answer you tomorrow morning when I will be in front of Inventor.
Hope it helps.
Dutt Thakar
LinkedIn
Message 12 of 20
_dscholtes_
Well, the above statements are based on the info I've found in the Object Browser of the VBA editor. However, I just tried the following code:
Dim oOcc As ComponentOccurrence
Set oOcc = ThisApplication.CommandManager.Pick(kAssemblyLeafOccurrenceFilter, "Select a component to test (or press ESC to quit)")
MsgBox oOcc.Definition.IsContentMember, vbInformation, "test"
and it works perfectly. It either goes True or False.
[Edit] @blandb Btw, with 170 solutions, you should be some kind of programmer 😛
Message 13 of 20
blandb
Most of my solutions are on the Inventor side of things, not iLogic. I can handle basic iLogic stuff, but this kind of stuff is over my head.
@dutt.thakar
I tried this, but I get an error stating that oDef is not defined, which it isnt, and.....I dont know how lol
Dim oDoc As AssemblyDocument Dim oPattern As OccurrencePattern
oPattern = oDoc.ComponentDefinition.OccurrencePatterns.Item("FRONT INTERMEDIATE POST PATTERN")
For Each oPattern In oDef.OccurrencePatterns For Each oOcc As ComponentOccurrence In oElement.Occurrences If oOcc.Definition.Document.FullFileName.Contains(CCPath) = False Component.Color(oOcc.Name) = "FNSH000510 (38/60060)" End If Next Next
Message 14 of 20
A.Acheson
@blandb
It is actually used  previously but not referenced as oDef.
  • If you back track  oPattern and remove "Item("Your Pattern Name") "you will be able to reference all patterns in your document.
oPatterns = oDoc.ComponentDefinition.OccurrencePatterns
  • Back track again and remove ".OccurrencePatterns." This will get reference to components in your Document
'Declaration
oDef  As AssemblyComponentDefinition
'Declaration
oDef
You can also  declare it by using below or replace oAsmCompDef with oDef , Sometimes it is useful to use more descriptive declarations.
Dim oAsmCompDef As AssemblyComponentDefinition
https://www.augi.com/articles/detail/inventor-ilogic-notes-for-assembly-drawings
Like wise  you could display what your looking for as
For Each oPattern In oDoc.ComponentDefinition.OccurrencePatterns
 Hope this helps.
Regards
Alan
Message 15 of 20
blandb
Sorry, just don't get it.
Message 16 of 20
A.Acheson
@blandb
I changed oDef out and put in oDoc.ComponentDefinition. The rest I managed to sort with a For loop to count how many patterns in the document then loop through .
I couldn't get  below lines to function. So the other for Loop  was used.
I am sure there is an easier way to accomplish this I am just not sure how. Below is working anyhow
' Counts the amount of patterns in the Document
Dim oPatternCount As Integer = oDoc.ComponentDefinition.OccurrencePatterns.Count
'Shows how many patterns in the assembly
MessageBox.Show(oPatternCount, "iLogic")
Dim i As Integer
For i = 1 To oPatternCount
	oPattern = oDoc.ComponentDefinition.OccurrencePatterns.Item(i)
		If Component.IsActive(oPattern.Name) = True Then
			MessageBox.Show(oPattern.Name, "iLogic")
				      				 Component.Color(oOcc.Name) = "Beech"
							End If
					Next
				Next
		End If
	Next
Regards
Alan
Message 17 of 20
dutt.thakar
@blandb
 The code written by @A.Acheson  is also another way to accomplish, but as I was mentioning you can iterate through each pattern and check if it is suppressed it won't go in it and change the color but, you do not need to specify differently each pattern if you want to iterate through all of them and change the color. See below code, where I am not using any counter and iterating through each pattern in an assembly and checking if it is suppressed or not, and if not then only it will iterate through all the elements and change the color of non-content center parts.
				If Component.IsActive(oPattern.Name)= True
				For Each oElement In oPattern.OccurrencePatternElements
		      				 Component.Color(oOcc.Name) = "Yellow"
					End If
				Next
				Next
			End If
			Next
Hope this will be a help.
Dutt Thakar
LinkedIn
Message 18 of 20
A.Acheson
@dutt.thakar
I had attempted that method but had not removed the variable referencing the named pattern and the elements within that pattern.
oPattern = oDoc.ComponentDefinition.OccurrencePatterns.Item(”Enter Pattern Name Here”)
Every day a school day. Need to spend more time studying 🙈
Thank you for showing the way.
Regards
Alan
Message 19 of 20
blandb
Thanks everyone for you help. To circle back around to this point, if I DID want 3 separate patterns to be different color, what is the syntax..is it what I have shown here??
oPattern = oDoc.ComponentDefinition.OccurrencePatterns.Item("pattern 1 description")
oPattern2 = oDoc.ComponentDefinition.OccurrencePatterns.Item("pattern 2 description")
oElements2 = oPattern2.OccurrencePatternElements
oPattern3 = oDoc.ComponentDefinition.OccurrencePatterns.Item("pattern 3 description")
oElements3 = oPattern3.OccurrencePatternElements
If Component.IsActive("pattern 1 description") = True Then
			End If
		Next
	Next
End If
If Component.IsActive("pattern 2 description") = True Then
	For Each oElement2 In oElements2
		For Each oOcc As ComponentOccurrence In oElement2.Occurrences
			End If
		Next
	Next
End If
If Component.IsActive("pattern 3 description") = True Then
	For Each oElement3 In oElements3
		For Each oOcc As ComponentOccurrence In oElement3.Occurrences
			End If
		Next
	Next
End If
Message 20 of 20
dutt.thakar
@blandb
If the above code works for you, that's great and you can proceed with it, Another solution I have is, try the below code, in which you do not need to define three patterns (i.e. oPattern1, oPattern2, oPattern3 etc. ) separately.
		If Component.IsActive(oPattern.Name)= True And oPattern.Name ="Pattern 1 Name"
			End If
		Next
		Next
	End If
	If Component.IsActive(oPattern.Name)= True And oPattern.Name ="Pattern 2 Name"
		       Component.Color(oOcc.Name) = "Red"
		End If
	     Next
	     Next
	End If
	If Component.IsActive(oPattern.Name)= True And oPattern.Name ="Pattern 3 Name"
		    Component.Color(oOcc.Name) = "Blue"
		End If
	Next
	Next
	End If
Next
Dutt Thakar
LinkedIn
