Check In to Vault files not from Inventor using i-logic
Hi All,
Is there a way to to use i-logic to check in (copy) non inventor files (PDF & DXF).
Our company requires to store in vault pdf's and dxf's of the drawings once approved. Currently need to manually add it by dragging folders to right place. Folders structure - DXF, PDF, INV (in INV are all Inventor files iam, ipt.idw).
Thank you very much.
SometimesInventorMakesMeAngry
You can export dxf and pdf from an Inventor rule, but you may or may not be able to check them in from an Inventor rule. You can ask in the Vault customization forum about it, but you may have to create a Vault extension with Visual Studio.
