Assembly Events for deleting WorkPoint / WorkPlane
FINET_Laurent
Advisor Advisor
FINET_Laurent
Dear all, bonjour.
Here bellow one code snippeds that will fire an event when deleting an occurrence inside an assembly (with several cuts for clarity) :
        Private WithEvents asmEvents As Inventor.AssemblyEvents
        Public Sub Activate(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate
            g_inventorApplication = addInSiteObject.Application
            asmEvents = g_inventorApplication.AssemblyEvents
        End Sub
        Private Sub asmEvents_OnDelete(ByVal DocumentObject As AssemblyDocument, ByVal Occurrence As ComponentOccurrence, ByVal BeforeOrAfter As EventTimingEnum, ByVal Context As NameValueMap, ByRef HandlingCode As HandlingCodeEnum) Handles asmEvents.OnDelete
            MsgBox("Test")
        End Sub
It works fantastic, but that doesn't trigger when deleting work points or work planes, which seems normal to me. How could I achieve such behaviour, maybe using an other existing event that I'm not aware of ?
Note that I would need to get the handles on that WorkPoint / WorkPlane that get deleted somehow.
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
FINET_Laurent
Hellooooooo,
Got it thank you ❤️
        Private WithEvents _DocEvents As DocumentEvents
        Private Sub TestButton_OnExecute() Handles TestButton.OnExecute
            Dim doc As AssemblyDocument = g_inventorApplication.ActiveDocument
            _DocEvents = doc.DocumentEvents
        End Sub
        Private Sub test(ByVal Entity As Object, ByVal BeforeAfter As EventTimingEnum, ByVal Context As NameValueMap, ByRef HandlingCode As HandlingCodeEnum) Handles _DocEvents.OnDelete
            Dim WorkPoint As WorkPoint = Entity
            MsgBox(WorkPoint.Point.X)
        End Sub
Kind regards,
FINET L.
mateusz_baczewski
Hi, I just have a quick question—does such an event handler need to be implemented as an Inventor add-in?
If you found it helpful, a "Like" would be much appreciated!
If this post solved your problem, please mark it as "Solution.".
