Part Document Save as Error
muthukumar.kVVK9E
muthukumar.kVVK9E
Dear Friends,
i am developing the Standalone App in Inventor API using VB.net.
this below error occurring not frequently, sometimes...
While saving the updated part doc, getting the following Error.
System.ArgumentException: 'The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))'
Code Snippet:
PartDoc.Update2()
Dim PartFileName As String = ""
PartFileName = DwgFolderPath & "\Bunker_Top.ipt"
PartDoc.SaveAs2(PartFileName, True)  ---> this Line getting Error
Kindly give the Solution .
Thanks in advance
mateusz_baczewski
Your code seems to look fine, especially since you mentioned that this error occurs rarely. Therefore, if you're creating a standalone application, try debugging the code and see what causes this error.
Maybe PartFileName = DwgFolderPath & "\Bunker_Top.ipt" // =Bunker_top.ipt or PartDoc is null. It's hard to determine based on what you sent.
If you found it helpful, a "Like" would be much appreciated!
If this post solved your problem, please mark it as "Solution.".
ryan.rittenhouse
I agree. Most of the time when I see this error the filename is wrong. The other possibility I've seen with this failure is that the file already exists and is read only. You might want to throw in a check for that.
If this solved your problem, or answered your question, please click Accept Solution.
Curtis_Waguespack
Hi @muthukumar.kVVK9E ,
What is your reason to use SaveAs2 rather than SaveAs ?
I think you can likely just use SaveAs
Dim PartDoc = ThisDoc.Document
PartFileName = "C:\Temp" & "\Bunker_Top.ipt"
PartDoc.SaveAs(PartFileName, True)
Typically we would not use SaveAs2, unless specifically wanting to set some save options.
Example:
https://help.autodesk.com/view/INVNTOR/2025/ENU/?guid=GUID-SaveOptions
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oOptions.Value("PromptSaveForMigration") = False
PartDoc.SaveAs2(PartFileName, True, oOptions)
Hope that helps,
Curtis
