Assembly constraint limits on/off
CCarreiras
Mentor Mentor
CCarreiras
Hi!
I m searching for a simple thing, just a line able or unable the max and min limits in assembly constrains.
i tryed something like the code below, but i believe this is not so simple...
SyntaxEditor Code Snippet
Constraint.IsActive("mate") = True
mate.ConstraintLimits.MaximumEnabled = True
mate.ConstraintLimits.MinimumEnabled = True
CCarreiras
bradeneuropeArthur
Follow this:
Public sub Mates ()
Dim a As MateConstraint
MsgBox ThisDocument.ComponentDefinition.Constraints.Count
Set a = ThisDocument.ComponentDefinition.Constraints.Item(1)
a.ConstraintLimits.MaximumEnabled = False ' or True
a.ConstraintLimits.MinimumEnabled = False ' or True
End Sub
Public Sub insert()
Dim a As InsertConstraint
End Sub
Public Sub Flush()
Dim a As FlushConstraint
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
