Arange All Linear dimension
vvvxxvvv333
Message 1 of 17
vvvxxvvv333
Guys @Michael.Navara  @JelteDeJong  @MjDeck
You know how to solve even impossible tasks. Can you find a solution for me?
When changing the parameters of a part, the dimensions in the drawing fly off.
But I want to get the correct position.
Method ChainDimensionSet.Arrange( BaseDimension As LinearGeneralDimension )
It does not work for me or I do not know how to use it correctly, it centers the text but the size itself does not move to the right place. If you run a rule to count the number of linear dimensions, it turns out that the ChainDimensionSet is counted as separate dimensions. Maybe they can be collected in separate collections and then properly sorted by type. If you can't sort by designation here
and position them by specifying the coordinates?
Does anyone solve this?
Replies (16)
Message 2 of 17
Michael.Navara
Try this for first ChainDimensionSet
Dim drawing As DrawingDocument = ThisDoc.Document
Dim sheet As Sheet = drawing.ActiveSheet
Dim cds As ChainDimensionSet = sheet.DrawingDimensions.ChainDimensionSets(1)
cds.Arrange(cds.Members(1))
Message 3 of 17
vvvxxvvv333
Thanks for the reply Yes, your rule aligns text between callout lines.
 But the dimension itself is not transferred to the correct position as specified in "E" and "D"
 What would "Arange" do with a set of linear dimensions
Message 4 of 17
vvvxxvvv333
You can also center dimension text using this rule (without selecting a separate CainDimensionSet)
Sub Main()
'  a reference to the active drawing document
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
'  a reference to the active sheet
Dim oSheet As Sheet
oSheet = oDoc.ActiveSheet
Dim oDrawingDim As DrawingDimension
' Iterate over all dimensions in the drawing and
' center them if they are linear or angular.
For Each oDrawingDim In oSheet.DrawingDimensions
	If TypeOf oDrawingDim Is LinearGeneralDimension Or _
		TypeOf oDrawingDim Is AngularGeneralDimension Then
		Dim oLength As Double
		Call oDrawingDim.DimensionLine.Evaluator.GetLengthAtParam(0, 1, oLength)
		If oLength > 0.6 Then Call oDrawingDim.CenterText
	End If
Next
End Sub
But here is not to arrange dimension lines in a parametric distance depending on each other using standard methodsю if CainDimensionSet gets into the collection. He doesn't move and stays in the wrong position.
I need to get this result
Message 5 of 17
vvvxxvvv333
It seems impossible to get the desired result using standard Inventor tools. But it may be possible to read the existing coordinates of the dimension lines. And then calculate and assign the correct ones?
Message 6 of 17
vvvxxvvv333
and even so, these dimensions respond to the @JelteDeJong
 rule.
        Dim doc As DrawingDocument = ThisApplication.ActiveDocument
        Dim oSheet As Sheet = doc.ActiveSheet
        Dim oview As DrawingView = osheet.DrawingViews(1)
        'Dim dimension As GeneralDimension
        Dim oTg = ThisApplication.TransientGeometry
        For Each dimension As DrawingDimension In oSheet.DrawingDimensions
            Dim midPointText As Point2d = dimension.Text.Origin
            Dim midPointView = oview.Center
            Dim textHeight = 0.5
            Dim newX As Double
            Dim newY As Double
            Dim deltaX As Double = (oview.Width * 0.5) + 0.6
            Dim deltaY As Double = (oview.Height * 0.5) + 0.6
            If (midPointText.X > midPointView.X + oview.Width / 2) Then
                newX = midPointView.X + deltaX
                newY = midPointView.Y
            End If
            If (midPointText.X < midPointView.X - oview.Width / 2) Then
                newX = midPointView.X - deltaX - textHeight
            End If
            If (midPointText.Y > midPointView.Y + oview.Height / 2) Then
                newY = midPointView.Y + deltaY + textHeight
            End If
            If (midPointText.Y < midPointView.Y - oview.Height / 2) Then
                newY = midPointView.Y - deltaY
            End If
            Dim newMidPoint As Point2d = oTg.CreatePoint2d(newX, newY)
            dimension.Text.Origin = newMidPoint
        Next
Can someone please fix this to give me the expected result?
Message 7 of 17
robertast
in 2021 Method ChainDimensionSet.Arrange was assigned [INVGEN-58548]. correct the error
Message 8 of 17
vvvxxvvv333
it's been three years and they haven't. Not sure if they will do it at all. That's why I'm looking for a roundabout way to solve this.
Well, I managed to move the dimensions, but they don't quite fit in the right place. I'm weak in programming, and those who are gurus don't want to help
Dim oFirstDim As DrawingDimension = Nothing
Dim oTg As TransientGeometry = ThisApplication.TransientGeometry
Dim oview As DrawingView = oSheet.DrawingViews(1)
' We find the first size and save its position
    If TypeOf dimension Is LinearGeneralDimension Then
        oFirstDim = dimension
        Exit For
    End If
Next
If oFirstDim Is Nothing Then
    MessageBox.Show("No size found on the drawing")
    Exit Sub
End If
Dim oDimPoint As Point2d = oFirstDim.Text.Origin
Dim dDist As Double = 1.0 ' the specified distance between the sizes
' We arrange the rest of the dimensions at a given distance from the first one
    If Not dimension Is oFirstDim AndAlso TypeOf dimension Is LinearGeneralDimension Then
        Dim oDimPointNew As Point2d = oTg.CreatePoint2d(oDimPoint.X + dDist, oDimPoint.Y)
        dimension.Text.Origin = oDimPointNew
        oDimPoint = oDimPointNew
		dimension.CenterText
    End If
Next
oSheet.Update()
Message 9 of 17
vvvxxvvv333
@Michael.Navara @WCrihfield  @bradeneuropeArthur @JelteDeJong
Can you take a look at what I've already created and correct the mistakes?
On the right side, the dimensions are already moving almost correctly.
Can you help modernize the code for the rest (left, right, top, and bottom)?
Dim newX As Double
Dim newY As Double
Dim counter As Integer = 0
Dim xValues As New List(Of Double)
    midPointText = dimension.Text.Origin
    If midPointText.X > midPointView.X + oview.Width / 2 Then
        deltaX += counter * 0.6
        counter += 1
        If Not xValues.Contains(midPointText.X) Then
            xValues.Add(midPointText.X)
        End If
        newY = midPointText.Y
    Else
        newX = midPointText.X
    End If
    For i As Integer = 0 To xValues.Count - 1
        If Math.Round(midPointText.X, 2) = Math.Round(xValues(i), 2) Then
            deltaX = (oview.Width * 0.5) + 0.6 * i
        End If
    Next
    dimension.Text.Origin = oTg.CreatePoint2d(newX, newY)
Next
Message 10 of 17
vvvxxvvv333
I will add files with a new rule
Maybe it is necessary to create a separate list of the distances at which the dimensions should be placed, and by comparing the position number with the existing dimensions, the required distance should be taken from that list?
Well, help me solve this problem, without your help I won't succeed
Message 11 of 17
robertast
@vvvxxvvv333  It seems that this can be solved
@JelteDeJong how about beer?
I promise a beer to the person who solves this problem
Message 12 of 17
jaimin.ja.3
Please go through the following link which provides a code for iLogic - Center & Arrange Dimensions - created by @ClintBrown3D. I have used this code before and it worked perfectly for me.
iLogic – Centre & Arrange Dimensions – Clint Brown
Message 13 of 17
vvvxxvvv333
it does not place the CainDimensionSet i at the correct distance from the drawing. It matches all other dimensions but not CainDimensionSet. I need to solve the problem if the set of dimensions also includes these dimensions so that they are all aligned equally.
Message 14 of 17
vvvxxvvv333
I have this initial posture
 using any handling rules I can find I get this
 But I had to get it this way
Message 15 of 17
romu51
Have a look at this:
https://clintbrown.co.uk/2020/07/11/ilogic-centre-arrange-dimensions/
  • it works well on randomly placed linear dimensions.
  • it can get messy with the angular dimensions when overlapping linear ones.
  • doesn't recentre the dimension when the rule had been previously applied and you want to update after you changed the model.
I regularly use it to tidy things up.
Message 16 of 17
vvvxxvvv333
What did I tell you above? This dimension of the circuit does not follow any rules that can be found on the Internet. It takes a lot of time to fix it
Watch the video if you don't believe it, after running the rules, the Chain dimensions remain in the wrong position
Message 17 of 17
vvvxxvvv333
I wrote this using "ChatGPT", it works almost fine. But I couldn't do it perfectly
I'm sure the programming gurus here could fix the AI bugs and solve this problem.
