iLogic Radio box Cancel "x" Button detection
james.johnston.2
james.johnston.2
How do I detect when the "x" button is pressed on a radio box?
DesignMethod1 = InputRadioBox("Select Design Method", "Pipe Diameter", "Flow Rate", True, Title:="Design Method")
A.Acheson
Hi @james.johnston.2
There seems to be no method to handle that return value if the close button is pressed so you will always receive a return value of boolean type.  See help page
Return Value
Type: Boolean
True if the first option was selected. False otherwise.
Regards
Alan
