Apprentice Server Issues with 2020.2 update
Raider_71
Raider_71
Hi is anyone else having an issue when using Apprentice server since 2020.2 update. We have some code that's not working anymore. Especially when working with Document Occurrences and ReferencedFileDescriptors.
Even the AssemblyTree ApprenticeServer sample that comes in the DeveloperTools SDK does not work anymore.
Any feedback would be great.
bradeneuropeArthur
Maybe you need to update the reference in the project again to the newer version of inventor (Inventor 2020.2)
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Raider_71
Hi
The project is linked to getting the dll from the GAC which should be the latest version??
Also the file version of the dll = 24.1.0 which is whats in the Inventor install folder also.
