Apprentice Server 2022 Printing issues
sfriedrich
sfriedrich
We have upgraded a Vault Custom Job from 2021 to 2022, including Inventor 2022.  We are using ApprenticeServer to print an Inventor DWG to PDF using Adobe driver.  This all worked fine in 2021, however, in 2022 we are randomly getting the following message:
"Failure to create the graphics processing capability necessary to display the geometry requested.  Please update your display driver to the most recent version."
On my test system I have an Invidia Quadro M2000M, and have updated the drivers.  This is happening on multiple machines now.
I can launch Inventor 2022 and print the DWG in question to PDF without the message showing up.
Any advice/ideas would be greatly appreciated.
bradeneuropeArthur
The graphic driver is updated and the issue is solved correct?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
sfriedrich
No , I was pointing out that the error occurs only when printing with Apprentice Server, I can open the DWG in Inventor and print it fine. The issue seems to be related to Apprentice Serer.
lukas.pichlerZKM73
was there a solution found to this problem?
