Applying char length rule to all assemblies/parts in an assembly
GICain
GICain
Greetings all!
Let me preface by saying I code like a toddler.
What I'm trying to do is have a rule that checks if the Stock Number is > 18 characters and the Description is > 40 characters. If it is, I have an error message that displays, warning the designer.
I have 2 problems.
  • I need this to work for assemblies/parts created before today. The event triggers placed on a standard part/assy file will only apply to anything created after today.
    • I have a dirty way to get around this by using iLogicVb.RunExternalRule("ruleFileName") in an existing rule and piggy backing off existing triggers. Plan is to use that for 3-6 months until we get through the older stuff.
  • The other issue is the rule I created only checks the current open file. If there are issues with 3 parts in an assembly, it just returns the error of the assembly 3x.
I tried searching the forums but didn't find anything or maybe I wasn't asking the right question.
Code posted below and thanks in advance.
Best,
Gabe
If Len(iProperties.Value("Project", "Description")) > 40 And Len(iProperties.Value("Project", "Stock Number")) > 18 Then
	MessageBox.Show("Error, Description Exceeds 40 Characters" _
	& vbLf & "" _'blank
	& vbLf & "Error, SAP Exceeds 18 Characters" _
	& vbLf & "" _ 'blank
	& vbLf & ThisDoc.FileName(True) _
	& vbLf & ThisDoc.Path, "Desc & SAP Error")
Else If Len(iProperties.Value("Project", "Description")) > 40 And Len(iProperties.Value("Project", "Stock Number")) <= 18 Then
	& vbLf & ThisDoc.Path, "Desc Error")
Else If Len(iProperties.Value("Project", "Description")) <= 40 And Len(iProperties.Value("Project", "Stock Number")) > 18 Then
	MessageBox.Show("Error, SAP Number Exceeds 18 Characters" _
	& vbLf & ThisDoc.Path, "SAP Error")
End If
Gabe Cain
Structural Designer/Engineering Checker
JelteDeJong
The following rule will check a document and all referenced documents that have been saved before now (DateTime.Now). I guess if you save it as an external rule and then trigger it on before save then you will get what you wanted.
Sub Main()
    Dim doc As Document = ThisDoc.Document
	CheckDocument(doc)
	For Each refDoc As Document In doc.AllReferencedDocuments
		CheckDocument(refDoc)
	Next
End Sub
Private Sub CheckDocument(doc As Document)
    Dim info As New System.IO.FileInfo(doc.FullFileName)
	If (info.LastWriteTime < DateTime.Now()) Then
		Dim propSet = doc.PropertySets.Item("Design Tracking Properties")
		Dim stockNumber = Len(propSet.Item("Stock Number").Value)
		Dim description = Len(propSet.Item("Description").Value)
		If description > 40 And stockNumber > 18 Then
					& vbLf & doc.FullFileName, "Desc & SAP Error")
		ElseIf description > 40 And stockNumber <= 18 Then
					& vbLf & doc.FullFileName, "Desc Error")
		ElseIf description <= 40 And stockNumber > 18 Then
					& vbLf & doc.FullFileName, "SAP Error")
		End If
	End If
End Sub
Jelte de Jong
Blog: hjalte.nl - github.com
GICain
@JelteDeJong,
Works great, thank you!
The only issue is that older parts won't have the global trigger so my plan is to piggy back off a rule already in place until we work through the older projects.
I also have a plan to make a rule with the sole intent of running other rules not currently in place with global triggers.
Thanks again,
Gabe
Gabe Cain
