View rep ilogic not acting the same since 2023
dwweekly
Message 1 of 10
dwweekly
I just noticed some of my ilogic is failing in 2023
I think it is related to the "Master" to "[Primary]" change
 I have 2 view reps labeled 12345 SOW FULL (full model) and 12345 SOW ONLY (shows what has changed) in an .iam (assembly model)
In my idw (drawing)  I create a view using the 12345 SOW ONLY rep
and then I use the Ilogic to create the overlay to my settings
It worked fine in 2022
but now it errors to line 18 (last line)
What must I change?
oObj = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a drawing view.")
If IsNothing(oObj) Then Exit Sub
If Not TypeOf oObj Is DrawingView Then Exit Sub
Dim oView As DrawingView = oObj
oDVRepName = oView.DesignViewRepresentation
oPRepName = oView.ActivePositionalRepresentation
Dim oDoc As DrawingDocument= ThisDoc.Document
Dim oSheet As Sheet = oDoc.ActiveSheet
ViewNameLen = Len(oDVRepName)
NewViewNameLen = ViewNameLen - 5
NewViewNameExtract = Mid(oDVRepName, 1, NewViewNameLen)
FullView = NewViewNameExtract & " FULL"
 Dim oOverlayView As DrawingView
' 	oOverlayView = oSheet.DrawingViews.AddOverlayView(oView, "Master", FullView, True, kHiddenLineRemovedDrawingViewStyle, False)
oOverlayView = oSheet.DrawingViews.AddOverlayView(oView, oPRepName, FullView, True, kHiddenLineRemovedDrawingViewStyle, False)
Replies (9)
Message 2 of 10
A.Acheson
Their is one error on the oDVRepName string variable. Correction is below. This was tested in INV 2020.  If you can post any error messages you might have this will help out also.
oDVRepName = oView.ActiveDesignViewRepresentation
Regards
Alan
Message 3 of 10
jdasilvaS39UQ
Did you ever find a solution to that error? I am also running into this issue if there is no positional representation on my assembly.
Message 4 of 10
WCrihfield
Hi @jdasilvaS39UQ.  Can you show us what both tabs of the error message dialog says when it throws the error?  And can you show us what your code up to that point looks like.  And what version of Inventor are you currently using?  Some of these types of things can be pretty difficult to debug remotely.  I just opened a drawing of an assembly, picked the drawing view, and checked the value of the DrawingView.ActivePositionalRepresentation property, as a test.  The code ran just fine, and showed me that the value was "[Primary]".  But I'm using 2024.0.1 version, so things might be slightly different.
Wesley Crihfield
(Not an Autodesk Employee)
Message 5 of 10
jdasilvaS39UQ
We are using Inventor 2023.2.1.
Here is the error message:
DrawingView.ActivePositionalRepresentation also returns "[Primary]" for me but when I try to pass it in as an argument for addoverlayview, its gives me the error above, parameter incorrect.
This is the assembly without an additional positional representation which gives the error
If I add an additional positional representation, the code works fine and accepts "[Primary]" as an argument
Here is my code
Imports System.Collections.Generic
Class SparePartsListHighlightRed
	Shared cutToLengthItems As New List(Of String)
	Public oColor As Color
	Public oBlue As Color
	Public oRed As Layer
	Public oTG As TransientGeometry
	Public oDrawDoc As DrawingDocument
	Public sparesSheet As Sheet				' We will track of our spares sheet object
	Public hasSparesSheet As Boolean		' Keep track if we need to make a sheet
	Public oDrawingView As DrawingView
	Public oDataSets As GraphicsDataSets
	Public oClientGraphics As ClientGraphics
Public Sub Main
'Definitions for highlighting
Dim oSketch As DrawingSketch
Dim oDC As DrawingCurve
' Set a reference to the drawing document.
oDrawDoc = ThisDoc.Document
If oDrawDoc.Sheets(1).DrawingViews.Count < 1 Then Exit Sub	' User hasn't placed their view yet
oDrawingView = oDrawDoc.Sheets(1).DrawingViews(1)			' Get a reference to the first drawing view placed on the first sheet
															' This is where we will grab our model referene for the parts list
'		Highlght Spares Items
' We will label our spare parts sheet in order to know which sheet to run our code on
' If a spare parts sheet doesn't exist, we need to create it
	Dim oSheet As Sheet					' Just need this for the for loop
	' Check if any are named spare parts and save a reference while we're at it
	For Each oSheet In oDrawDoc.Sheets
'		Logger.Debug("Sheet name: " & Left(oSheet.Name, (InStrRev(oSheet.Name, ":")-1)))
		If Left(oSheet.Name, (InStrRev(oSheet.Name, ":")-1)) = "Spare Parts" Then		' Need to remove the :# at the end of each sheet
			hasSparesSheet = True
			sparesSheet = oSheet
	Next
'sparesSheet = oDrawDoc.Sheets(1)
'hasSparesSheet = True
	' If we couldn't find it, there is nothing to highlight
		If hasSparesSheet = False Then
			MsgBox("No spare parts sheet found in drawing.")
			Exit Sub
	' If there are no drawing views on the sheet, we don't need to do anything
		If sparesSheet.DrawingViews.Count < 1 Then
			MsgBox("No drawing views found on the sheet to highlight parts on.")
			Exit Sub
	oColor = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
	oBlue = ThisApplication.TransientObjects.CreateColor(0, 0, 0)
	oTG = ThisApplication.TransientGeometry
'	oDataSets = sparesSheet.GraphicsDataSetsCollection.Item("CG_Test3")
'		oDataSets.Delete
'		oClientGraphics = sparesSheet.ClientGraphicsCollection.Item("CG_Test3")
'		oClientGraphics.Delete
'		Exit Sub
	' Set up a vew rep for spare parts
		' Creates a new View Rep "Active Components" and then turns all Reference Components visibility to off.
		'It only turns On active Components at this level.
		'Then returns back to original active View Rep when logic was initiated.
		Dim odoc As Document
		Dim oCompDef As ComponentDefinition
		odoc = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
		oCompDef = odoc.ComponentDefinition
		'Sets initial View Rep
		oActiveViewRep = oCompDef.RepresentationsManager.ActiveDesignViewRepresentation
		'Creates New View Rep
		Dim oviewrep2 As DesignViewRepresentation
		Try
		oCompDef.RepresentationsManager.DesignViewRepresentations.Item("Spare Parts").Activate
		Catch
		 oviewrep2 = oCompDef.RepresentationsManager.DesignViewRepresentations.Add("Spare Parts")
		End Try
		'This sets some parameters to turn off ref components
		oAssemblyComponents = oCompDef.Occurrences
		Dim oOccurrence As ComponentOccurrence
		    For Each oOccurrence In oAssemblyComponents
				Try
			        If oOccurrence.Definition.Document.PropertySets.Item("Inventor User Defined Properties").Item("Wear Item").Expression = "Yes" Then
						oOccurrence.Visible = True
					Else
						oOccurrence.Visible = False
				Catch
					Try
					Catch
					End Try
				End Try
				If oOccurrence.SubOccurrences.Count > 0 Then
					TraverseAssembly(oOccurrence.SubOccurrences)
		    Next
		'Sets the view rep back to the one that was active before the rule was executed
'		oActiveViewRep.Activate
	'Loop through all views that currently exist on the active sheet
	For Each oDrawingView In sparesSheet.DrawingViews
'		Try
'			oDataSets = oDrawingView.GraphicsDataSetsCollection.Item("CG_Test3")
'			oDataSets.Delete
'			oDataSets = oDrawingView.GraphicsDataSetsCollection.Add("CG_Test3")
'		Catch
'		End Try
'		Try
'			oClientGraphics = oDrawingView.ClientGraphicsCollection.Item("CG_Test3")
'			oClientGraphics = oDrawingView.ClientGraphicsCollection.Add("CG_Test3")
'		Catch
'		End Try
'		TraverseAssembly(oModelDoc.ComponentDefinition.Occurrences)
		MsgBox(oDrawingView.ActivePositionalRepresentation)
'		Dim overlayView As DrawingView
'		overlayView = sparesSheet.DrawingViews.AddOverlayView(oDrawingView, oDrawingView.ActivePositionalRepresentation, "Spare Parts", False, kShadedHiddenLineDrawingViewStyle)
'		overlayView.ViewStyle = DrawingViewStyleEnum.kFromBaseDrawingViewStyle
		sparesSheet.DrawingViews.AddOverlayView(oDrawingView, oDrawingView.ActivePositionalRepresentation, "Spare Parts", False, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle, False)
'		iLogicVb.UpdateWhenDone = True
	Next
ThisApplication.ActiveView.Update
' Update the document
'oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument.Update
'InventorVb.DocumentUpdate
End Sub
Sub TraverseAssembly(oOccs As ComponentOccurrences)
		    For Each oOccurrence In oOccs
				If Not oOccurrence.Suppressed Then
					Try
						Else
					Catch
						Try
						Catch
						End Try
					End Try
					Logger.Debug(oOccurrence.Name & " - TYPE: " & oOccurrence.Type)
		    Next
End Sub
End Class
Message 6 of 10
WCrihfield
Well, the error is definitely happening at that line of code, but it simply does not tell us which of the inputs it is having a problem with.  I would try checking the value of oDrawingView.ActivePositionalRepresentation just before that line somewhere, and if its value is either "[Primary]" or "" (empty String), I would leave that input entry in that line of code as an empty String ("") instead, and try that.  If the model does not have any PositionalRepresentations available, it may simply not like you trying to specify one by name, even if it was the default one.
Wesley Crihfield
Message 7 of 10
jdasilvaS39UQ
I have a textbox before that line,
it shows "[Primary]"
I tried passing "[Primary]", tried an empty string "" and the old "Master" as values and get the same error for all of them
Message 8 of 10
WCrihfield
OK.  I have not tested this myself lately, so I will take your word for it.  That does sound like a bug then.  And it does seem to be a 'required' input parameter, so we can't simply not specify anything there.  Maybe try specifying the keyword 'Nothing' there instead of an empty String.  Or maybe vbNullString.
Wesley Crihfield
Message 9 of 10
jdasilvaS39UQ
That was a good idea but same result.
I can work around it by adding a position rep to the assembly but that doesn't get to the root of the issue.
Message 10 of 10
A.Acheson
Hi @jdasilvaS39UQ
This is the instructions for PosRep Object. It is required so you will need to create one. I guess the designers didn't build a situation where the PosRep would be empty.
"Input String that specifies the positional representation to use for the overlay view. The input string must the name of an existing position representation in the assembly referenced by the parent view. The method returns a failure if a representation with this name is not found in the referenced assembly."
Regards
Alan
