Ilogic copy design tube and pipe route not copied
Tim.Malkowski
Tim.Malkowski
Dear All,
I have recently moved on to inventor 2023.  I use Ilogic copy design when coping a project that contains tube and pipe assembly as it is the only way to copy these assemblies without vault.
Since moving on to inventor 2023 i have not done the copy design process till today and have found that the routes of the pipe work have not copied over. 2020 was the version before i used and there were no issues.
during the selection i confirmed the routes were included as i have done this process twice now and neither time the routes have copied over.
Has anyone had similar issues or can suggest anything please.
A.Acheson
@johnsonshiue I believe this is an issue with out of the box ilogic copy design as opposed to any custom copy design. This post likely belongs in the inventor forum. Maybe you can test a sample set and check if there is an issue your end.
Regards
Alan
Tim.Malkowski
Apologies, I thought that was where i posted.
A.Acheson
You are correct in where you posted it but it was likely moved due to the ilogic keyword but it is the standard application that you using correct?
Can you post a screenshot of what files do get copied? Are the tube runs copied along with the folder structure your using. This is INV 2020 so unfortunately I cannot check INV 2023
Johnson can hopefully move the post back and check the results on his end.
Regards
Alan
Tim.Malkowski
So,  the icopy design seems to work, but isn't producing the route files and pipe part files. When opening the assembly with the tube and pipe in it. It is asking for the files with the prefix i assigned during the icopy.  the other thing is I tried this with just a the tube and pipe file and the icopy worked fine.  it just seems to be when it is part of a larger assembly this happens.  The issue i have is i need it to be part of the larger assembly to keep the connection and references to work.
The items in the red boxes don't get produce in the icopy
