ApplicationEvents losing my Code
bindlmi
bindlmi
I have a problem with my C# addin and Inventor 2023.3.1. I didn't create the addin from scratch, I just maintained it. I think it's already .NET 8.0 (but I'm not sure)
However, the addin is loaded and the ApplicationEvents OnSaveDocument and OnDocumentChange also work at first. After some time or some actions (I couldn't find out when exactly) these events don't trigger my code anymore, as if Inventor had lost this assignment. When I unload and reload the addin it works again for a while...
Does anyone have any ideas/advice on how I can continue to troubleshoot this? I already had several MessageBoxes at the beginning and at the end of my code, but at some point they just stopped appearing.
If you want me to upload any files, please tell me which ones. (I can program a bit, but only know a little bit about the whole thing)
I am grateful for any help 🙂
Michael.Navara
Usually this is because you don't keep the reference to the ApplicationEvents object. Look at following samples if it is your case.
Bad sample - Don't do this
public class SampleAddIn_Bad : ApplicationAddInServer
    private Inventor.Application inventorApp;
    public void Activate(ApplicationAddInSite addInSiteObject, bool firstTime)
        inventorApp = addInSiteObject.Application;
        //This event handler will be cleaned up by GarbageCollector
        inventorApp.ApplicationEvents.OnSaveDocument += ApplicationEvents_OnSaveDocument;
    private void ApplicationEvents_OnSaveDocument(_Document documentObject, EventTimingEnum beforeOrAfter, NameValueMap context, out HandlingCodeEnum handlingCode)
        //Do something here
        handlingCode = HandlingCodeEnum.kEventNotHandled;
Correct sample
public class SampleAddIn_Correct : ApplicationAddInServer
    private ApplicationEvents applicationEvents;
        //Keep the reference to the ApplicationEvents object at add-in level
        applicationEvents = inventorApp.ApplicationEvents;
        applicationEvents.OnSaveDocument += ApplicationEvents_OnSaveDocument;
        //Do something here
bindlmi
thanks for the tip. I had the bad example of course.
I will test this and observe the next few days - feedback will follow
