Application Options, File Tab, Texture folder - change the path using the API
ACEDeSmedt
ACEDeSmedt
I can't seem to find the API key to change the Texture folder option.
If this is the solution, push the solution button 😉 (and maybe some kudos)
Autodesk Product Design Suit - Ultimate edition (Subscription)
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi Klass,
Please find the following VBA code to change Texture folder path through API.
ThisApplication.FileOptions.TexturePath = "Folder path"
Please feel free to contact if there is any doubt.
If solves your problem, click on "Accept as solution" / give a "kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
ACEDeSmedt
I see I forgot to mention my Inventor Version. This option is not present in Inventor 2015. Do you know when this options was introduced?
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi Klass,
"TexturePath" API is available in Inventor 2017 and above versions.
If solves your problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
