Set the offset of component to zero and ground them
Ezekiel12
Ezekiel12
I found really nice and useful piece of code that sets the offset of components to zero and ground them. I am now trying to change it to do it only for one part in assembly (that I specifically choose in code). So for example, do this only for component "123A:1". And I am failing miserably so far. Does anyone know?
Original code:
http://adndevblog.typepad.com/manufacturing/2014/10/set-the-offset-of-components-to-zero-and-ground-...
Dim doc As AssemblyDocument
doc = ThisApplication.ActiveDocument
Dim tr As TransientGeometry
tr = ThisApplication.TransientGeometry
Dim occ As ComponentOccurrence
For Each occ In doc.ComponentDefinition.Occurrences
  ' If it's suppressed we cannot do
  ' anything with it
  If Not occ.Suppressed Then
    Call occ.SetTransformWithoutConstraints( _
      tr.CreateMatrix())
    occ.Grounded = True
Next
Ezekiel12
Well I finally got it to work 🙂
Dim entity = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select Component:")
If (Not entity Is Nothing) And _
(TypeOf entity Is ComponentOccurrence) Then
  If Not entity.Suppressed Then
   	 		Call entity.SetTransformWithoutConstraints( _
    	  	tr.CreateMatrix())
   	 		entity.Grounded = True
