Application.ActiveColorSheme ScreenColor does not change
M.Zirk
M.Zirk
I have tried to change the Screencolor of the ActiveColorSheme.
No Error, but nothing happens.
Dim inv As Inventor.Application = CType(selection.Document.Parent, Inventor.Application)
This does not work
inv.ColorSchemes.Item(inv.ActiveColorScheme.Name).ScreenColor.SetColor(0, 0, 0)
inv.ActiveColorSheme.ScreenColor.SetColor(0, 0, 0)
This works:
inv.ColorSchemes.BackgroundType = Inventor.BackgroundTypeEnum.kOneColorBackgroundType
What is going wrong?
Manfred
Curtis_Waguespack
Hi @M.Zirk
I don't think they allow us to set this. The API help says the ScreenColor property is read only.
I hope this helps.
Curtis
M.Zirk
Hello Curtis,
thank you for your infomation.
Manfred
