Apperence/Material Color
paulschuepbach
Message 1 of 8
paulschuepbach
Hello all,
I have the following problem since the 'RenderStyle' Object has been removed from the API: some Materials in Material Assets do have a Color information, such as RGB-Value and Opacity:
generic_diffuse 127   127   63   1
Other Materials do not have a Color information - when the graphic style has a Texture (see pic).
How can I get the RGB-Code from a Material (or from a Face etc....) when the Apperance has a Texture?
Best, Paul
Replies (7)
Message 2 of 8
bradeneuropeArthur
Have you migrated?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 8
paulschuepbach
Yes, all Parts and Assemblies are migrated
Message 4 of 8
bradeneuropeArthur
You need to migrate the material library too.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 8
paulschuepbach
??? this are Materials from the 2018 Material Library... - what shell to be migrating then?
Message 6 of 8
bradeneuropeArthur
The old one to the new definitions...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 8
paulschuepbach
I don't see why there shell be the need for any migration. Again: this are Materials from the Inventor Matrerial Library 2018. My question was: how do I get the RGB-code from the used Material - some Materials have a RGB code in the definibition, others don't - if they have a texture.
In other words: what is the Colors RGB code of a face (for example) ?
Message 8 of 8
bradeneuropeArthur
Ok explanation!
The material used in the document defer from the library you are using.
So if you would like to have them the same as in the past, you need to migrate the old library to a new 2018 library. They have a complete other definition, and are stored in a complete different database.
That's why you need to migrate the old library you were using to a new 2018 library file.
Hope this will help you.....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
