API Select Points from 3D Modell
florian_wenzel
florian_wenzel
'Inventor 2022 & Visual Studio
i try to create a WorkPlane with 3 Points.
AddByThreePoints
The 3 Points, i want to pick up from 3D Modell.
The Final Result should look like This:
So i  want to select 3 Points:
Edge EndPoint or EdgeMidPoint etc...
But it dosent work.
This is my Code:
Imports System.Runtime.InteropServices
Imports Inventor
Imports Microsoft.Win32
Module CommandFunctionButton_01
Public Sub CommandFunctionfweButton_01()
Dim oPartDoc As PartDocument = g_inventorApplication.ActiveDocument
Dim oCompDef As PartComponentDefinition = oPartDoc.ComponentDefinition
Dim oTO As TransientObjects = g_inventorApplication.TransientObjects
Dim oTG As TransientGeometry = g_inventorApplication.TransientGeometry
Dim oWorkPoint1 As Object
oWorkPoint1 = g_inventorApplication.CommandManager.Pick(SelectionFilterEnum.kWorkPointFilter, "Pick a Points1")
Dim oWorkPoint2 As Object
oWorkPoint2 = g_inventorApplication.CommandManager.Pick(SelectionFilterEnum.kWorkPointFilter, "Pick a Points2")
Dim oWorkPoint3 As Object
oWorkPoint3 = g_inventorApplication.CommandManager.Pick(SelectionFilterEnum.kWorkPointFilter, "Pick a Points3")
Dim oWorkPlaneA1 As WorkPlane
oWorkPlaneA1 = oCompDef.WorkPlanes.AddByThreePoints(oWorkPoint1, oWorkPoint2, oWorkPoint3, True)
End Sub
End Module
In Enums / SelectionFilterEnum Enumerator which Methods should i use?
I want simple select Point on: Edge EndPoint or EdgeMidPoint etc...
i'm not able to Pick up any Points:
How can i do this.
Thanks for any Suggestion.
A.Acheson
It looks like the boolean construction plane is at fault here. Changing it to false allows the plane to be shown visibly. Boolean of true creates a construction plane that is not shown in the browser or graphically. See API help description here.
oWorkPlaneA1 = oCompDef.WorkPlanes.AddByThreePoints(oWorkPoint1, oWorkPoint2, oWorkPoint3, False)
You can check the type with the Construction property.
oWorkPlaneA1 = oCompDef.WorkPlanes.AddByThreePoints(oWorkPoint1, oWorkPoint2, oWorkPoint3, true)
MessageBox.Show(oWorkPlaneA1.Construction, "Title")
Using sketch points also works so you can skip the WorkPoint creation.
oPoint1 = g_inventorApplication.CommandManager.Pick(SelectionFilterEnum.kSketchPointFilter, "Pick a Points1")
Regards
Alan
JelteDeJong
Getting the midpoint is very difficult (if possible at all for your purpose). Have a look at this post.  But if you can live with 3 vertexes/points then you can do it like this.
Dim oWorkPoint1 As Vertex = g_inventorApplication.CommandManager.Pick(SelectionFilterEnum.kAllPointEntities, "Pick a Points1")
Dim oWorkPoint2 As Vertex = g_inventorApplication.CommandManager.Pick(SelectionFilterEnum.kAllPointEntities, "Pick a Points2")
Dim oWorkPoint3 As Vertex = g_inventorApplication.CommandManager.Pick(SelectionFilterEnum.kAllPointEntities, "Pick a Points3")
Dim oWorkPlaneA1 As WorkPlane = oCompDef.WorkPlanes.AddByThreePoints(oWorkPoint1, oWorkPoint2, oWorkPoint3, False)
Jelte de Jong
Blog: hjalte.nl - github.com
florian_wenzel
Thanks 🙂
Yeah, it should be a Vertex, and False as you mentioned before.
You Right, its very Tricky to select a MidPoint, but i will try it.
The EndPoint works Fine!
