[API] - Remove details from Revit Features
gmassart
gmassart
Is there a way to use the Revit Features recognition functions with vba ?
Such as remove details or fill the holes/opening (don't know the exact name of the functions, I use the French version)
Guillaume MASSART
AFFIVAL SAS
Inventor Pro 2022
AlexFielder
Hi @gmassart,
I'm not sure about the Revit Features recognition but there is another way and the command is called Shrinkwrap.
You can find an API (vba) example documented here:
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-9E92691A-7EEA-4BA8-94D7-3F64AA9ABA30
(The above help is for 2018, but the approach should be the same)
Cheers,
Alex.
gmassart
Thank you
I will give a try
Guillaume MASSART
AFFIVAL SAS
Inventor Pro 2022
