API - place file in assembly, user defined position.
Jef_E
Message 1 of 1
Jef_E
Hi there,
I'm trying to create a method that will place a file into an assembly, and I want it to be like when you choose place file in Inventor.
The file is been chosen by it's path. And now it needs to be placed. I know a way how to place the file at coordinates, but I want the file to be on the cursor and the user be able to choose where to drop it.
How do you do achieve this? I tried a programming help search but I can only find thing about the event and dialog.
FileDialog.InsertMode() As Boolean
normally I just place and ground, but that not good now 😞
    Public Function Place_and_Ground_Part(ByVal oDef As AssemblyComponentDefinition,
                                       ByVal path As String) As ComponentOccurrence
        ' Set a reference to the assembly component definintion.
        ' This assumes an assembly document is open.
        ' Set a reference to the transient geometry object.
        Dim oTG As TransientGeometry
        oTG = oInvApp.TransientGeometry
        ' Create a matrix.  A new matrix is initialized with an identity matrix.
        Dim oMatrix As Matrix
        oMatrix = oTG.CreateMatrix
        ' Set the translation portion of the matrix so the part will be positioned
        ' at (3,2,1).
        oMatrix.SetTranslation(oTG.CreateVector(0, 0, 0))
        ' Add the occurrence.
        Dim oOcc As ComponentOccurrence
        oOcc = oDef.Occurrences.Add(path, oMatrix)
        ' Make sure the master part is grounded
        oOcc.Grounded = True
        Return oOcc
    End Function
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Replies (0)
