iLogic rule to save idw parts of an assembley as bwg blocks
i have looking for a iLogic rule to save my assembley as dwg with blocks
The Blocks should be the Parts that my assembly consist of.
One part or one assembley in assembley - one block.
Can you please help me out
Best regards
Alex
Owner2229
Hi, do you mean to create these drawings, or just open them, update and save?
Or do you mean to open ".idw" drawing and save it as ".dwg"?
The first one would require some specific conditions to be met and it has some limitations.
E.g.: It would always generate the model's view with the same rotation.
        In most cases it won't include dimensions.
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Hi and thank you for your replays.
Sorry for the delay!
I have recive a rule from you. Open idw, run rule and save it as dwg, adn than close it.
When I open the dwg i have my obejct and views as lines.
But ist there a way to make from the parts blocks in autoCAD.
Best regards!
Alex
