Inconsistent ComponentDefinition.Type and InvalidCastException
Here's my code.
occ = assemdoc.ComponentDefinition.Occurrences.Add(partFile, location);
bool isPartComponentDefinition = occ.Definition.Type == ObjectTypeEnum.kPartComponentDefinitionObject; // true
((PartComponentDefinition)occ.Definition).Parameters["BDiameter"]); // System.InvalidCastException
It's throwing InvalidCastException on (PartComponentDefinition)occ.Definition, even though occ.Definition.Type == ObjectTypeEnum.kPartComponentDefinitionObject.
Is this a bug? Or do I have to do something before the occurrence from Occurrences.Add becomes valid?
Here is stripped down version of the method I call to add occurrences to an assembly and an example of how I call it.
Public Function AddOccurrence(ByVal AssyCompDef As Inventor.AssemblyComponentDefinition, _
                                 ByVal OccurrName As String, _
                                 ByVal PosMtrx As Inventor.Matrix) As Inventor.ComponentOccurrence
        Dim NewOccurr As Inventor.ComponentOccurrence
        Try
             NewOccurr = AssyCompDef.Occurrences.Add(OccurrName, PosMtrx)
  Return NewOccurr
        Catch ex As Exception
                MessageBox.Show("could not place file " & OccurrName, "error", MessageBoxButtons.OK)
  Return Nothing
        End Try
 End Function
 Protected Friend Sub CreateSubAssy(fullpath As String, newAssyName as String)
        _invApp.SilentOperation = True
        Dim oAssyDoc As Inventor.AssemblyDocument
        Try
            oAssyDoc = CType(_invApp.Documents.Add(DocumentTypeEnum.kAssemblyDocumentObject, _
                                                     TemplateFileName:=gTemplatePath & "CD80vSealAssy.iam", _
                                                     CreateVisible:=False), AssemblyDocument)
            oAssyDoc.SaveAs(fullpath & newAssyName & ".iam", False)
            Dim oAsmCompDef As AssemblyComponentDefinition
            oAsmCompDef = oAssyDoc.ComponentDefinition
            Dim oPositionMatrix As Inventor.Matrix
            oPositionMatrix = _invApp.TransientGeometry.CreateMatrix
            'place part
            Dim sFileName As String = fullpath & "PartName.ipt"
            Dim oPart As Inventor.ComponentOccurrence
            oPart = AddOccurrence(oAsmCompDef, sFileName, oPositionMatrix)
        Finally
            _invApp.SilentOperation = False
            oAssyDoc.Save2()
            oAssyDoc.Close(SkipSave:=False)
        End Try
 End Sub
Yeah, that's essentially what we've got too, but that occurrence you get at
the end there, that's where my code comes in, and I get the type-cast
exception. It's like it's not really a full-fledged occurrence - like it's
only got part of the occurrence info.
are you trying to modify a parameter in the part with the following line?
((PartComponentDefinition)occ.Definition).Paramete​rs["BDiameter"]); // System.InvalidCastException
Yeah, that's my ultimate goal, and then I ran into this problem.
try something like this to change the parameter value or expression
Dim oPartCompDef as PartComponentDefinition
oPartCompDef = occ.Definition
oPartCompDef.Parameters.Item("BDiameter").Value = xxx 'or .Expression = "xxx"
