API onDocumentChange not triggering
gert-leonvanlier
gert-leonvanlier
I have the following code. When saving, closing or opening, the application events are triggered, but the change event does not. Does anyone have a clue?
public void Activate(ApplicationAddInSite addInSiteObject, bool firstTime)
                try
                    // Initialize AddIn members.
                    Globals.invApp = addInSiteObject.Application;
                    Globals.invApp.ApplicationEvents.OnDocumentChange += onChange;
                    Globals.invApp.ApplicationEvents.OnSaveDocument += onSaving;
                    Globals.invApp.ApplicationEvents.OnCloseDocument += onClosing;
                    Globals.invApp.ApplicationEvents.OnOpenDocument += onOpen;
                catch (Exception ex)
                    MessageBox.Show("Unexpected failure in the activation of the add-in " + System.Environment.NewLine + System.Environment.NewLine + ex.Message);
            private bool isSaving = false;
            private void onChange(_Document DocumentObject, EventTimingEnum BeforeOrAfter, CommandTypesEnum ReasonsForChange, NameValueMap Context, out HandlingCodeEnum HandlingCode)
                if (BeforeOrAfter == EventTimingEnum.kAfter)
                    MessageBox.Show("Hello");
                HandlingCode = HandlingCodeEnum.kEventNotHandled;
            private void onOpen(_Document DocumentObject, string FullDocumentName, EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
isSaving);
            private void onClosing(_Document DocumentObject, string FullDocumentName, EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
                if (BeforeOrAfter == EventTimingEnum.kBefore)
            private void onSaving(_Document DocumentObject, EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
bradeneuropeArthur
This is a DocumentEvent!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
gert-leonvanlier
But using the Event Watcher there is also OnDocumentChange in ApplicationEvents. It is also listed as an object of ApplicationEvents when I program.
But I will try DocumentEvents too.
JelteDeJong
I have very similar code that does work.  The main difference is that in my code the event object (Globals.invApp.ApplicationEvents.OnDocumentChange) is in the same object as where the event handlers are created.  I know that the events objects are very sensitive for the garbage collector.  (Check this post
Jelte de Jong
Blog: hjalte.nl - github.com
gert-leonvanlier
@JelteDeJongI read the other post, but I don't really understand what it means. And then in particular this senctence: "When subscribing to events from .NET, you need to also hold on to a reference to the xxxEvents object (in this case, ApplicationEvents). Otherwise, the temporary reference you used to subscribe to the event gets garbage-collected."
gert-leonvanlier
I foudn the issue after I came across this post this morning. Ater I set Embed Interop Types to False and run the code, the onChange event was triggered.
