API implementation getting crazy
A.BeeseH8JKW
A.BeeseH8JKW
Hello everyone,
I have a problem that I simply cannot solve on my own without help.
I am using an API to create somewhat more complex components.
These are created by using sketches and the Elevation operation.
Since arcs are used in the 3D sketch, a leading edge must be selected to use the elevation.
It has now been noticed that created lines/arcs are connected to each other using the smallest arcs.
This is not stored in the API and cannot be explained.
Unfortunately, a support request to Autodesk has already been rejected.
Do you have any idea why these unwanted arcs are created by Inventor?
I cannot upload the API, but I can upload an excerpt for the line creation.
Thank you for your efforts
Alex
Translated with DeepL.com (free version)
bradeneuropeArthur
Please share some pictures or files to explain what you mean.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Frederick_Law
You're not coding API.
You're using Inventor API to code.
Sketch3DOptions:
https://help.autodesk.com/view/INVNTOR/2025/ENU/?guid=GUID-Sketch3DOptions
abdullah_elq
Try setting this value to 0
A.BeeseH8JKW
I have inserted a screenshot of the sketch here.
For explanation
1st section: 200mm length
2nd section: 900mm length
However, you can see an R5
I can't understand that.
cidhelp
Hello @A.BeeseH8JKW ,
if you use the API-Command SketchLines3D.AddByTwoPoints, then there is a third parameter called UseAutoBend:
oSk.SketchLines3D.AddByTwoPoints(oPt1, oPt2) - UseAutoBend is on
oSk.SketchLines3D.AddByTwoPoints(oPt1, oPt2, False) - UseAutoBend is off
