API & derived part
API & derived part
Jef_E
API & derived part
Jef_E
Hi there,
I'm trying to build a skeleton modeling tool, but i'm kinda stuck. I have a 'Master' part that creates sketches when required. After this i would like to create a new part (which is working) & then create a derived part (which is also working). But now i want to select not all sketches to derive but only a few based on the sketch name.
For now i have this: Create part, Set the derived component, Create the derived component.
        Dim oProjectMgr As DesignProjectManager = oInvApp.DesignProjectManager
        Dim oProject As DesignProject = oProjectMgr.ActiveDesignProject
        Dim oTemplatesPath As String = oProject.TemplatesPath
        Dim oNewDoc As PartDocument = oInvApp.Documents.Add(DocumentTypeEnum.kPartDocumentObject, oTemplatesPath & "\Standard.ipt", True)
        Dim oDerivedPartDef As DerivedPartUniformScaleDef
        oDerivedPartDef = oNewDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.CreateUniformScaleDef(oMasterLoc)
        oDerivedPartDef.ScaleFactor = 1
        oDerivedPartDef.ExcludeAll()
        oDerivedPartDef.UseColorOverridesFromSource = False
        Call oNewDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Add(oDerivedPartDef)
So for my settings i chose .ExcludeAll to eliminate all unwanted sketches.
But now it needs to add Sketch1 & Sketch2 for example and also Param_A & Param_B
But i think if i know howto derive the sketches i can also figure out the parameters.
Any ideas?
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
MechMachineMan
Withn the Derived Part Transform Definition object, there is a Parameters Property that contains the Derived Part Entities Object. That should be a start.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Jef_E
This works for, found it on the mod the machine site i think!
        Dim oDerivedComp As DerivedPartComponent = oNewDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents(1)
        oDerivedPartDef = oDerivedComp.Definition
        Dim oDerEntity As DerivedPartEntity
        For Each oDerEntity In oDerivedPartDef.Parameters
            If oDerEntity.ReferencedEntity.Name = "C02_t" Then
                oDerEntity.IncludeEntity = True
        Next
Inventor 2014 SP2
kevin_gauthierLLF3A
Observer
Observer
What is oMasterLoc?
kevin_gauthierLLF3A
Observer
Observer
What is "oMasterLoc"?
