Anyone know how to set up a 3D mouse?
I just got my first 3D mouse. It's not a spacemouse as I dont accept the idea of letting go of an (almost) unlimited number of hotkeys in addition to the ludicrous price for a spacemouse with an (almost) acceptable number of keys. I instead got a regular mouse with integrated joysticks, namely Lexip for a fraction of the price.
As far as I understand it the manufacturer has to provide the drivers and UI for the integration, but while I'm waiting for a response from customer support I'd like to know if there's a workaround. I can't figure out how to customize the inventor orbit input so as to emulate the orbiting with the joystick and seeing as how spacemouse apparantly virtually has a monopoly on this market I'm having trouble finding any info on the topic wich doesnt directly relate to spacemouse.
Does anyone have a good idea on how to get a non-spacemouse working for inventor?
Is there a good reason why autodesk makes it so difficult to use other input devices?
Thanks!
JamieVJohnson2
if your non connexion 3d mouse can assign keys, the keyboard shortcuts for orbit in Inventor are either F4, or use Ctrl+Middle Mouse Button.
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
Thanks for the reply.
Yes that's how I'm used to orbiting by using the keyboard + mouse, but I'm looking for a method for orbiting that doesnt require the use of two device inputs where only one would normally suffice. I mean shift orbiting is fine and I'm used to it, wich is why I would never pay 700$ just to avoid having to hold shift by buying a space mouse wich is only good for that one single use as far as I can tell.
For instance, if I were able to map keys to the different angles (wich the mouse allows for, but as far as I can tell, Inventor does not) I would be more or less sorted. The only annoyance in that case would be not having analog input. Atleast that should work untill I get a response from the manufacturer wich lists autodesk programs as supported.
NachoShaw
You should have got the 3d connection notebook mouse. $100, 2 buttons, wireless and best of all, no complicated set up. Plug it in, perfect 3d orbital
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Thank you for the reply.
No, a device with that few input options defeats the purpose for me. Like I said, i am not willing to give up an unlimited number of hotkeys and commands just to avoid having to click shift.
Switching back and forth between devices is not efficient either.
mrnemo
Community Visitor
Community Visitor
You might consider (if the buttons are enough) a _used_ Spacemouse Pro Wireless.  If you set up an ebay automated search, within a year or so--assuming you can wait--you might find one for $150 (at least that was what happened for me).  I don't know if that falls within what you'd consider a reasonable price or not...   Anyway, the Spacemouse I got was in like-new condition and makes modeling soooo much nicer and more fun.  I use Rhino mostly but am starting to improve my Fusion360 skills some now too.
  I know I'm also not answering your actual question, sorry.
 When I look at the control panel (on a Mac) for the Spacemouse it looks like I can set up all the button and other custom mappings there, rather than in Fusion360, just fyi.
