iLogic for Part & Assembly Cost Calculations
arkelec
arkelec
I want to use an external rule to add iProps & then use any field data already present to calculate cost.
The adding of the iProps is (for the most), sorted.  What I need to do next is:
  1. Convert text from iProps to numbers
  2. Perform a calculation using two or more of the conversions
  3. Populate the calc result to another iProp
So I want "Unit_Buy".  This will be the result of "Unit_Trade" with "Discount" applied.
Here's what I have so far for the conversion of "Unit_Trade":
Dim Unit_Trade As String = iPropGetStr("Unit_Trade", "0")
Dim Unit_Trade_NUM As Integer = iPropGetStr("Unit_Trade_NUM", (Int32.TryParse(Unit_Trade, Unit_Trade_NUM)))
Dim Discount As String = iPropGetStr("Discount", "0")
Dim Discount_NUM As Integer = iPropGetStr("Discount_NUM",Int32.TryParse("Discount", Discount_NUM))
During the development of the iLogic, I've added an iProp from "Unit_Trade_NUM" so I can see if it works.  It doesn't.  The iProp is added with the format YES/NO.
The workflow at present is:
  1. Run the rule
  2. Add data to the empty fields on a form that loads
  3. Close form & re-run rule
Before each time for step 1 above, I make sure any existing iProp with the format Y/N is deleted, so the rule will add it.
I'm not sue if I've got the syntax for the TryParse correct, or have I have missed something else entirely?
clutsa
So this seems to work for me even though it doesn't seem like it should.
Dim Unit_Trade As String = iProperties.Value("Custom", "Unit_Trade")
Dim Discount As String = iProperties.Value("Custom", "Discount")
Dim Unit_Buy As Double = Unit_Trade * Discount
iProperties.Value("Custom", "Unit_Buy") = Unit_Buy
MessageBox.Show(iProperties.Value("Custom", "Unit_Buy"), "Title")
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
clutsa
This does a bit more to help get your text to a number format if you don't have only numbers as the text.
'MessageBox.Show("Unit_Trade = " & Unit_Trade, "Title")
Dim Unit_Trade_Num As Double = Val(Replace(Unit_Trade,"$","")) 'Val returned '0' if preceded by '$'
'MessageBox.Show("Unit_Trade_Num = " & Unit_Trade_Num, "Title")
Dim Discount As String = iProperties.Value("Custom", "Discount") 'discount is enter as '20%'
Dim Discount_Num As Double = Val(Discount) / 100 'val returns '20' not '.20' as we need for a percent
Dim Unit_Buy As Double = Unit_Trade_Num * Discount_Num
'MessageBox.Show("Unit_Buy = " & iProperties.Value("Custom", "Unit_Buy"), "Title")
There is also "CDblAny(myString)" you can try if "Val(myString)" isn't working for you.
chandra.shekar.g
Autodesk Support
Autodesk Support
@arkelec,
If value of custom iProperty is either "True" or "False", delete the existing custom iProperty. For deleting custom iProperty, refer the answered post in below forum discussion link.
https://forums.autodesk.com/t5/inventor-forum/how-to-remove-custom-iproperty-with-ilogic/td-p/436406...
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
arkelec
Thanks for the replies.  Apologies for the late reply, but work stuff etc.
In the end, I re-structured the whole thing & then most recently, have engaged someone to assist with the wider customising tasks.
The Boolean issue was because I was using an incorrect function.
Thanks again.
