add button to sizable winow (like the view cube)
omartin
omartin
I am trying to add a button to the top left corner, so even it the window is re-sized it will stay in the same spot sort of like the view cube or the origin.
But it doesn't have to rotate with the model like the view cube.
My original plan was just to create a form and set the location, but if I simply use:
myform..top/left = ...view(1).top/left it doesn't work out right. I cant find the relationship between vb's form co-ordinates and inventor's active window co-ordinates Smiley Frustrated
Was my reply Helpful ? send a Kudos or accept as solution
chandra.shekar.g
Autodesk Support
Autodesk Support
@omartin,
Hoping that Inventor connect design may be helpful to provide resizable window. For more details, refer below youtube link.
https://www.youtube.com/watch?v=turtuJBpxAU
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
