Any examples of using Workpoints?
I would like to add a workpoint to a part (manually) for other programming
purposes. Does anyone have any examples of: 1) Programatically naming a
workpoint. 2) Finding the named work point programatically. 3) Making the
named workpoint visible (which I think is something like "workpoint.visible=
true", but I can't find any examples of how to address the desired
workpoint).
Ed
There's a sample called "Work Point at Mass Center" that's part of the API
help. I think it demonstrates everything you asked about except the
visibility part.
Brian Ekins
Autodesk Inventor API Product Designer
"Ed Thompson" wrote in message
news:608ED00C34961C29C49843F7AD93DC39@in.WebX.maYIadrTaRb...
the
"workpoint.visible=
> workpoint).
> Thanks,
> Ed
Brian,
Excellent! I see that I didn't look quite close enough at the example.
Thanks!
Ed
"Brian Ekins" wrote in message
news:8F7E53C36154021423E205F8ACDF0330@in.WebX.maYIadrTaRb...
> visibility part.
> Brian Ekins
programming
a
> the
> "workpoint.visible=
> > workpoint).
> > Thanks,
> > Ed
Brian,
Is if possible in R6 to place a workpoint in an assembly?
I tried the following code, but something is wrong?
Dim Comp As ComponentOccurrence
Set Comp = ThisApplication.ActiveDocument.SelectSet.Item(1)
Dim oWorkPoint As WorkPoint
Set oWorkPoint = Comp.WorkPoints.Item("Test Point")
Ed
> visibility part.
> Brian Ekins
programming
a
> the
> "workpoint.visible=
> > workpoint).
> > Thanks,
> > Ed
Hi Ed,
Here's a sample that demonstrates creating work features in an assembly.
Public Sub AssemblyWorkFeatures()
' Get a reference to the assembly component definition.
Dim oCompDef As AssemblyComponentDefinition
Set oCompDef = ThisApplication.ActiveDocument.ComponentDefinition
' Get a reference to the TransientGeometry object.
Dim oTG As TransientGeometry
Set oTG = ThisApplication.TransientGeometry
' Create a work point at (0,0,0)
Dim oWPoint As WorkPoint
Set oWPoint = oCompDef.WorkPoints.AddFixed(oTG.CreatePoint(2, 0, 0))
oWPoint.Name = "My WorkPoint"
' Create a work axis through (3,1,0) and along the X axis.
Dim oWAxis As WorkAxis
Set oWAxis = oCompDef.WorkAxes.AddFixed(oTG.CreatePoint(3, 1, 0), _
oTG.CreateUnitVector(1, 0, 0))
oWAxis.Name = "My WorkAxis"
' Create a work plane that passes through (2,2,0) and is
' 45 degrees to the x-z plane.
Dim oWPlane As WorkPlane
Set oWPlane = oCompDef.WorkPlanes.AddFixed(oTG.CreatePoint(2, 2, 0), _
oTG.CreateUnitVector(0, 0, -1),
oTG.CreateUnitVector(-1, -1, 0))
oWPlane.Name = "My WorkPlane"
End Sub
-Brian
news:01AAE77274E35A1DC34C60EA90150C95@in.WebX.maYIadrTaRb...
> Brian,
> Thanks,
> Ed
API
> > visibility part.
> > Brian Ekins
> programming
naming
> a
Making
> > the
> > "workpoint.visible=
> > > workpoint).
> > > Thanks,
> > > Ed
