Hi Ed,
Here's a sample that demonstrates creating work features in an assembly.
Public Sub AssemblyWorkFeatures()
' Get a reference to the assembly component definition.
Dim oCompDef As AssemblyComponentDefinition
Set oCompDef = ThisApplication.ActiveDocument.ComponentDefinition
' Get a reference to the TransientGeometry object.
Dim oTG As TransientGeometry
Set oTG = ThisApplication.TransientGeometry
' Create a work point at (0,0,0)
Dim oWPoint As WorkPoint
Set oWPoint = oCompDef.WorkPoints.AddFixed(oTG.CreatePoint(2, 0, 0))
oWPoint.Name = "My WorkPoint"
' Create a work axis through (3,1,0) and along the X axis.
Dim oWAxis As WorkAxis
Set oWAxis = oCompDef.WorkAxes.AddFixed(oTG.CreatePoint(3, 1, 0), _
oTG.CreateUnitVector(1, 0, 0))
oWAxis.Name = "My WorkAxis"
' Create a work plane that passes through (2,2,0) and is
' 45 degrees to the x-z plane.
Dim oWPlane As WorkPlane
Set oWPlane = oCompDef.WorkPlanes.AddFixed(oTG.CreatePoint(2, 2, 0), _
oTG.CreateUnitVector(0, 0, -1),
oTG.CreateUnitVector(-1, -1, 0))
oWPlane.Name = "My WorkPlane"
End Sub
-Brian
"Ed Thompson" wrote in message
news:01AAE77274E35A1DC34C60EA90150C95@in.WebX.maYIadrTaRb...
> Brian,
> Is if possible in R6 to place a workpoint in an assembly?
> I tried the following code, but something is wrong?
> Dim Comp As ComponentOccurrence
> Set Comp = ThisApplication.ActiveDocument.SelectSet.Item(1)
> Dim oWorkPoint As WorkPoint
> Set oWorkPoint = Comp.WorkPoints.Item("Test Point")
> Thanks,
> Ed
> "Brian Ekins" wrote in message
> news:8F7E53C36154021423E205F8ACDF0330@in.WebX.maYIadrTaRb...
> > There's a sample called "Work Point at Mass Center" that's part of the
API
> > help. I think it demonstrates everything you asked about except the
> > visibility part.
> > Brian Ekins
> > Autodesk Inventor API Product Designer
> > news:608ED00C34961C29C49843F7AD93DC39@in.WebX.maYIadrTaRb...
> > > I would like to add a workpoint to a part (manually) for other
> programming
> > > purposes. Does anyone have any examples of: 1) Programatically
naming
> a
> > > workpoint. 2) Finding the named work point programatically. 3)
Making
> > the
> > > named workpoint visible (which I think is something like
> > "workpoint.visible=
> > > true", but I can't find any examples of how to address the desired
> > > workpoint).
> > > Thanks,
> > > Ed
