Angle dimension
Angle dimension
Angle dimension
Hi all,
I need an help, when I used Solidworks I had possibilities for insert angular dimension with a virtual line.
For example I need to indicate the angle in the cutted side of the imagine attached.
How can I insert the dimension of the angle without drawing a line?
Hope everything is clear.
CCarreiras
Hi!
It's not possible right now.
It's a good sugestion for the Ideias forum!!
CCarreiras
Thank you,
Hope to see a solution soon.
Regards.
CCarreiras
If so.... go to the page below and vote!!! Ask your friends to vote also   🙂
https://forums.autodesk.com/t5/inventor-ideas/angle-dimention-with-virtual-line/idi-p/7533584
CCarreiras
