AnchorPoints
AnchorPoints
AnchorPoints
I know how to get the anchor points from a dimension, but I can't seem to access them once I get them?  I have just this simple code:
  For Each oPartDim In oSketch.DimensionConstraints
    If oPartDim.Parameter.Name = "Angle" Then
      Debug.Print oPartDim.AnchorPoints
  Next oPartDim
 I've tried .item(0) .item(1), but I keep erroring out and I haven't seen anything else on these, I was hoping someone could show me how?
Vladimir.Ananyev
Try this sample code.  It prints anchor points coordinates using (a) 2d-points collection and (b) sketch points associated with given dimension constraint (here - ThreePointAngleDimConstraint). Note that AnchorPoints collection contains Point2D objects (not SketchPoint).
Private Sub Sketch_Dims_Test()
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oDef As PartComponentDefinition
    Set oDef = oDoc.ComponentDefinition
    Dim oSketch As PlanarSketch
    Set oSketch = oDef.Sketches.Item(1)
    Dim oDims As DimensionConstraints
    Set oDims = oSketch.DimensionConstraints
    'reference to 3-point angular dimension
    Dim oDim As ThreePointAngleDimConstraint
    Set oDim = oDims.Item(1)
    'coordinates of anchor 2d-points
    Dim oP As Point2d
    For Each oP In oDim.AnchorPoints
        Debug.Print oP.X, oP.Y
    Next
    Debug.Print
    'anchor sketch points
    Dim oSkp As SketchPoint
    Set oSkp = oDim.PointOne
    Debug.Print oSkp.Geometry.X, oSkp.Geometry.Y
    Set oSkp = oDim.PointTwo
    Set oSkp = oDim.PointThree
    Beep
End Sub
 Hope this helps.
Cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Thanks Vladimir,
That did the trick.  I'm guessing the code you provided is for 2014, in the bottom section I don't seem to have the "PointOne" option - but no matter, the part up above was what I needed.
Thanks again!
Vladimir.Ananyev
Good news.
Best regards!
Vladimir Ananyev
