error with ThisApplication.ApplicationAddIns.ItemById
sellis
sellis
Trying to export a PDF with PDF translator. Using sample "Save as PDF Translator Sample API Sample" from programers help, I created an addin but...
Getting error "Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))" on "ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")".
I created an addin starting with
Imports Inventor
Imports System.Runtime.InteropServices
Namespace IvPublish
    <ProgIdAttribute("IvPublish.StandardAddInServer"), _
    GuidAttribute("5404f6be-46bb-4bf2-b1b4-7a5e70b69e8f")> _
    Public Class StandardAddInServer
        Implements Inventor.ApplicationAddInServer
        ' Inventor application object.
        Public Property ThisApplication As Inventor.Application
 and activate starts with
        Public Sub Activate(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate
            ' Initialize AddIn members.
            ThisApplication = addInSiteObject.Application
 and command triggered with a button starts with
        Private Sub _ExportPdfAllButton_OnExecute(Context As NameValueMap) Handles _ExportPdfAllButton.OnExecute
            Dim PDFAddIn As TranslatorAddIn
            PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
 And that is where it fails... getting PDFAddin. Tried on two systems with same result...
Inventor 2014, Visual Studios 2012
Stan
sellis
Should also note that this works fine...
            Dim oSTEPTranslator As TranslatorAddIn
oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
