Adding Text to Inventor Dimension with iLogic or VBA
ccoomes
Message 1 of 24
ccoomes
Does anyone know how to add pre-defined text to a Selected Dimension with either iLogic or VBA?
I have to create lots of drawing with a lot of dimensions with the same wording.
The Layout is as follows:
<DIM> Maximum
Product Width
What I would like to do is select the Dimension, and then click and button on a form (or VBA USerform) that adds pre-defined text.
Has anyone been able to do this as it will make my life a lot simpler..
Replies (23)
Message 21 of 24
GeorgeWilliams
Did you find an answer to your question?  I am needing the same functionality.
After manually setting the dimension text with a parameter reference I inspected the formatted text on the dimension object to be ...
"<DimensionValue/><Parameter Resolved='True' ComponentIdentifier='ValidPathToMyPart' Name='Dim_A' Precision='2'>53.75</Parameter>"
If I then set the formatted text value with that same string, I get an "automation error, Unspecified error".  Maybe that isn't supported via the API?
George Williams
D3 Technologies - Automation Solutions
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
Message 22 of 24
George
I never managed to find a solution to this issue.
I also tried the method you have described, with the same results.
I have concluded that it is probably not possible to do this with the API; or if it is possible, I still don't know how to do it.
Thanks for your reply.
Message 23 of 24
Does anyone know the "<  />" code for GAUGE as a dimension text user parameter?
I see that "<DimensionValue/>" is for the dimension value, "<br/>" does a return to next line, <stack> does a stacked dimension, etc.
JCKCAD
Message 24 of 24
r_pruellage
Hello, i have found your solution with the adding text to dimension.
Is there a solution so add parameter to a dimension? The parameter is just added to a dimension. Example please see below.
In green my text added by hand
4 is a parameter
345 is a parameter
1380 is a catched dimension a shape of the geometri of the ipt and in best case it should look like below.
Is that possible? I dont neet to select dimension because the place is always the same with the added parameters.
