iLogic Design View Error
I'm getting an infrequent error with my code. Occasionally I get this error:
What does this mean and how can I fix it? Here's my code:
Dim doc as AssemblyDocument = ThisDoc.Document
Dim oAsmCompDef As ComponentDefinition
oAsmCompDef = doc.ComponentDefinition
Dim oCompOcc As Inventor.ComponentOccurrence
For Each oCompOcc in oAsmCompDef.Occurrences
oCompOcc.SetDesignViewRepresentation("Default", True)
Next
ThisApplication.ActiveView.Fit
 Any help would be greatly appreciated. Thanks guys.
adam.nagy
Autodesk Support
Autodesk Support
When trying to find the issue, first you can try to comment out more and more of your code until the error goes away.
In your case the first choice would be commenting out
Then if you found the line where the error happens, you can place it inside a try/catch and bring up a dialog with some info about the object where the error happened. E.g.:
Dim oDim doc as AssemblyDocument = ThisDoc.Document
Try
Catch
	MsgBox(oCompOcc.Name)
End Try
Next
Then try to make the same changes for the same object through the UI as well - it will probably fail there too, which should give you an idea about how to solve it.
Cheers,
Adam Nagy
Autodesk Platform Services
