adding panels to custom created ribbon tab help
bsnyderACLUW
bsnyderACLUW
Hi everyone,
I have created some code (with the help of others on this forum) that creates a tab on the ribbon (inventor).
So far it works great, I can execute my external rules from my created ribbon tab.
Although this works well, I want to organize it a bit better. i want to split some of the actions listed under drawings into separate panels within the created tab. I cant find any information on this.
The code is posted below:
Dim oRibbon As Inventor.Ribbon
Dim oDoc As Document
oDoc = ThisApplication.ActiveEditDocument
If oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
    oRibbon = ThisApplication.UserInterfaceManager.Ribbons.Item("Assembly")
    oType = "Assembly"
ElseIf oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
    oRibbon = ThisApplication.UserInterfaceManager.Ribbons.Item("Part")
    oType = "Part"
ElseIf oDoc.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
    oRibbon = ThisApplication.UserInterfaceManager.Ribbons.Item("Drawing")
    oType = "Drawing"
Else
    oType = "Unknown"
	Exit Sub
oName = "Silent-Aire_"
Try
oRibbon.RibbonTabs.Item(oName & oType).Delete
Catch
End Try
Dim oTab As Inventor.RibbonTab
oTab = oRibbon.RibbonTabs.Add(oName & oType, oName & oType, “Silent-Aire”)
oTab.Active = True
Dim oPanel As RibbonPanel
sPanelName = oName & " Tools"
oPanel = oTab.RibbonPanels.Add(sPanelName, oName & oType, oName & oType)
Dim oControlDefs As ControlDefinitions
oControlDefs = ThisApplication.CommandManager.ControlDefinitions
Dim oButtonsList As New ArrayList
If oType = "Drawing" Then
	'first panel (to be made)
	oButtonsList.Add("Ribbon_Executables.Reuse_Drawing")
	oButtonsList.Add("Ribbon_Executables.Center_Dimensions")
	oButtonsList.Add("Ribbon_Executables.Missing_Balloons")
	oButtonsList.Add("Ribbon_Executables.Sort_and_Hide_Partlist")
	'second panel (to be made)
	oButtonsList.Add("Ribbon_Executables.Issued_For_Construction")
	oButtonsList.Add("Ribbon_Executables.Add_Revision_Row")
	oButtonsList.Add("Ribbon_Executables.Hide_Revision_Row")
	oButtonsList.Add("Ribbon_Executables.Clear_Revisions_Batch")
	oButtonsList.Add("Ribbon_Executables.Clear_Revisions_Single")
	'third panel (to be made)
	oButtonsList.Add("Ribbon_Executables.Batch_Print_to_PDF")
	oButtonsList.Add("Ribbon_Executables.Single_Print_to_PDF")
	oButtonsList.Add("Ribbon_Executables.EDM_Printer_1")
	oButtonsList.Add("Ribbon_Executables.EDM_Printer_2")
	oButtonsList.Add("Ribbon_Executables.EDM_Printer_Crowsnest")
	oButtonsList.Add("Ribbon_Executables.PHX_Printer_Samsungx7600GX")
	oButtonsList.Add("Ribbon_Executables.PHX_Printer_Cannon_iR_ADV_C7260")
Else If oType = "Assembly" Then
	oButtonsList.Add("Ribbon_Executables.Open_All_Drawings")
	oButtonsList.Add("Ribbon_Executables.Go_To_Working_Folder")
	oButtonsList.Add("Ribbon_Executables.Total_Weight")
	oButtonsList.Add("Ribbon_Executables.Creat_Part_Drawing")
	oButtonsList.Add("Ribbon_Executables.Excel_BOM_Export")
Else If oType = "Part" Then
	oButtonsList.Add("Ribbon_Executables.Density")
	oButtonsList.Add("Ribbon_Executables.Copy_Design")
Dim oMacroDef As MacroControlDefinition
For Each oItem In oButtonsList
oMacroDef = oControlDefs.AddMacroControlDefinition(oItem)
	oPanel.CommandControls.AddMacro(oMacroDef, False)
Next
these are the splits i want to make:
Thanks everyone,
bradeneuropeArthur
Dim oFirstPanel As RibbonPanel
sFirstPanelName = oFirstName & " FirstPanelName"
oFirstPanel = oTab.RibbonPanels.Add(sFirstPanelName, oFirstName & oType, oFirstName & oType)
Dim oSecondPanel As RibbonPanel
sSecondPanelName = oSecondName & " SecondPanelName"
oSecondPanel = oTab.RibbonPanels.Add(sSecondPanelName, oSecondName & oType, oSecondName & oType)
And so on....
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bsnyderACLUW
Thank you so much for your reply
I have been fiddling with what you wrote in your post but I'm getting unspecified errors.
I'm assuming that the code you posted would just repeat where the original section was for how many panels I want but, how do I place specific buttons on specific panels? and is there anything else I should address later in the code?
Thank you,
bsnyderACLUW
ok, so this is where I am at:
oTab = oRibbon.RibbonTabs.Add(oName & oType, oName & oType, “Silent-Aire”)      '<----- creates ribbon tab
oTab.Active = True
sPanelName = "Tools"
oPanel = oTab.RibbonPanels.Add(sPanelName, oName & oType, oName & oType)        '<----- creates panel on ribbon tab
If oType = "Drawing" Then	'<----- this section creates the clickable buttons
	oButtonsList.Add("Ribbon_Executables.Reuse_Drawing")                        '<-----(VBA code name.button name)
Dim oRevisionPanel As RibbonPanel
sRevisionPanelName = "Revision Block"
oRevisionPanel= oTab.RibbonPanels.Add(sRevisionPanelName, oRevisionName & oType, oRevisionName & oType)        '<----- creates panel on ribbon tab
Dim aButtonsList As New ArrayList
	aButtonsList.Add("Ribbon_Executables.Issued_For_Construction")
	aButtonsList.Add("Ribbon_Executables.Add_Revision_Row")
	aButtonsList.Add("Ribbon_Executables.Hide_Revision_Row")
	aButtonsList.Add("Ribbon_Executables.Clear_Revisions_Batch")
	aButtonsList.Add("Ribbon_Executables.Clear_Revisions_Single")
Dim oPDFPanel As RibbonPanel
sPDFPanelName = "PDF Block"
oPDFPanel= oTab.RibbonPanels.Add(sPDFPanelName, oPDFName & oType, oPDFName & oType)        '<----- creates panel on ribbon tab
Dim bButtonsList As New ArrayList
	bButtonsList.Add("Ribbon_Executables.Batch_Print_to_PDF")
	bButtonsList.Add("Ribbon_Executables.Single_Print_to_PDF")
oMacroDef = oControlDefs.AddMacroControlDefinition(oItem)	                   '<----- tells inventor that these buttons will execute a command in VBA
Next
Dim oMacroDef2 As MacroControlDefinition
For Each oItem In aButtonsList
oMacroDef2 = oControlDefs.AddMacroControlDefinition(oItem)	                   '<----- tells inventor that these buttons will execute a command in VBA
	oRevisionPanel.CommandControls.AddMacro(oMacroDef2, False)
Next
Dim oMacroDef3 As MacroControlDefinition
oMacroDef3 = oControlDefs.AddMacroControlDefinition(oItem)	                   '<----- tells inventor that these buttons will execute a command in VBA
	oPDFPanel.CommandControls.AddMacro(oMacroDef3, False)
Next
I can get the oPanel and oRevisionPanel to show up but when I add the oPDFPanel it errors out.
am I missing something?
probably something stupid im not seeing
bsnyderACLUW
for other peoples reference, I have finished the program to include separated sections in the custom ribbon tool bar.
    oType = "Assembly"
    oType = "Part"
    oType = "Drawing"
Else
    oType = "Unknown"
	Exit Sub
oName = "Company Name "
Try
Catch
End Try
	oTab = oRibbon.RibbonTabs.Add(oName & oType, oName & oType, “company name”)
        'used to set the created tab as active tab
	'oTab.Active = True
	Dim APanel As RibbonPanel
	APanelName = oName & " Tools"
	APanel = oTab.RibbonPanels.Add(APanelName, oName & "Tools", oName & "Tools")
	Dim AButtonsList As New ArrayList
	AButtonsList.Add("Ribbon_Executables.Go To Working Folder")
	AButtonsList.Add("Ribbon_Executables.Reuse Drawing")
	AButtonsList.Add("Ribbon_Executables.Vault Check In")
	AButtonsList.Add("Ribbon_Executables.Precise View")
	AButtonsList.Add("Ribbon_Executables.Center View Labels")
	AButtonsList.Add("Ribbon_Executables.Center Dimensions")
	AButtonsList.Add("Ribbon_Executables.Sort and Hide Partlist")
	AButtonsList.Add("Ribbon_Executables.Missing Balloons")
	AButtonsList.Add("Ribbon_Executables.Update Balloons")
	AButtonsList.Add("Ribbon_Executables.Drawing Notes")
	AButtonsList.Add("Ribbon_Executables.Fastener Details")
	Dim BPanel As RibbonPanel
	BPanelName = oName & " Revisions"
	BPanel = oTab.RibbonPanels.Add(BPanelName, oName & "Revisions", oName & "Revisions")
	Dim BButtonsList As New ArrayList
	BButtonsList.Add("Ribbon_Executables.Add Revision Row Batch")
	BButtonsList.Add("Ribbon_Executables.Add Revision Row Single")
	BButtonsList.Add("Ribbon_Executables.Hide Revision Rows")
	BButtonsList.Add("Ribbon_Executables.Clear Revisions Batch")
	BButtonsList.Add("Ribbon_Executables.Clear Revisions Single")
	BButtonsList.Add("Ribbon_Executables.Empty  ")
	BButtonsList.Add("Ribbon_Executables.IFC Batch")
	BButtonsList.Add("Ribbon_Executables.IFC Single")
	Dim CPanel As RibbonPanel
	CPanelName = oName & " Printing"
	CPanel = oTab.RibbonPanels.Add(CPanelName, oName & "Printers", oName & "Printers")
	Dim CButtonsList As New ArrayList
	CButtonsList.Add("Ribbon_Executables.EDM Printer 1")
	CButtonsList.Add("Ribbon_Executables.EDM Printer 2")
	CButtonsList.Add("Ribbon_Executables.EDM Printer Crowsnest")
	CButtonsList.Add("Ribbon_Executables.PHX Printer 1")
	CButtonsList.Add("Ribbon_Executables.PHX Printer 2")
	CButtonsList.Add("Ribbon_Executables.PHX Printer 3")
	CButtonsList.Add("Ribbon_Executables.Single Print to PDF")
	CButtonsList.Add("Ribbon_Executables.Batch Print to PDF")
	For Each oItem In AButtonsList
		APanel.CommandControls.AddMacro(oMacroDef, False)
	Next
	For Each oItem In BButtonsList
		BPanel.CommandControls.AddMacro(oMacroDef, False)
	Next
	For Each oItem In CButtonsList
		CPanel.CommandControls.AddMacro(oMacroDef, False)
	Next
	'oTab.Active = True
	AButtonsList.Add("Ribbon_Executables.Remove Mass Prompt Assy")
	AButtonsList.Add("Ribbon_Executables.Open All Drawings")
	AButtonsList.Add("Ribbon_Executables.Batch Print All Drawings")
	AButtonsList.Add("Ribbon_Executables.Total Weight")
	AButtonsList.Add("Ribbon_Executables.Excel BOM Export")
	AButtonsList.Add("Ribbon_Executables.Set Designer Properties")
	AButtonsList.Add("Ribbon_Executables.Lazy Eye")
	Next
	'oTab.Active = True
	AButtonsList.Add("Ribbon_Executables.Remove Mass Prompt")
	AButtonsList.Add("Ribbon_Executables.Density")
	AButtonsList.Add("Ribbon_Executables.Create Part Drawing")
	AButtonsList.Add("Ribbon_Executables.Copy Design")
	AButtonsList.Add("Ribbon_Executables.Pilot Holes")
	Next
mgFNR8M
Hi.
Great code.
I've used your latest code on Inventor 2022.
How are you making the ribbon tabs visible automatically?
Does it need to be run on every file (open or new) with iTrigger?
EDIT: and how can I call iLogic rules from the new buttons?
bsnyderACLUW
yes, i am using triggers to run the code when i open a new file
