Adding menu items to Tools pulldown menu
Can anyone give me the specifics on adding a new menu item to this dropdown menu? TIA, Bob S.
In help do a search for "Environments" then click on the first item it returns " Environments" At the bottom of the page it shows adding a dropdown menu. Rather than adding a new one you would just have to find the tools dropdown, and add it to it. I believe in the SDK directory the UI example addin is the one help is discussing. -- Kent Keller Autodesk Discussion Forum Facilitator "Bob S." wrote in message news:41640766$1_2@newsprd01... > Can anyone give me the specifics on adding a new menu item to this > dropdown menu? > > TIA, > Bob S. > >
Kent, Thanks, I'll take a look at that. "Kent Keller" wrote in message news:416414d0_3@newsprd01... > In help do a search for "Environments" then click on the first item it > returns " Environments" At the bottom of the page it shows adding a > dropdown menu. Rather than adding a new one you would just have to find > the tools dropdown, and add it to it. > > I believe in the SDK directory the UI example addin is the one help is > discussing. > > -- > Kent Keller > Autodesk Discussion Forum Facilitator > > > "Bob S." wrote in message > news:41640766$1_2@newsprd01... >> Can anyone give me the specifics on adding a new menu item to this >> dropdown menu? >> >> TIA, >> Bob S. >> >> > >
Just curious; new with Inventor 9, isn't there a way to add menu items without using an add-in? Bob H. "Kent Keller" wrote in message news:416414d0_3@newsprd01... > In help do a search for "Environments" then click on the first item it > returns " Environments" At the bottom of the page it shows adding a > dropdown menu. Rather than adding a new one you would just have to find > the tools dropdown, and add it to it. > > I believe in the SDK directory the UI example addin is the one help is > discussing. > > -- > Kent Keller > Autodesk Discussion Forum Facilitator > > > "Bob S." wrote in message > news:41640766$1_2@newsprd01... > > Can anyone give me the specifics on adding a new menu item to this > > dropdown menu? > > > > TIA, > > Bob S. > > > > > >
Look in Help >> Context Tab >> Samples >> UI Customization. -- Kent Keller Autodesk Discussion Forum Facilitator "Bob H." wrote in message news:416536f7$1_3@newsprd01... > Just curious; new with Inventor 9, isn't there a way to add menu items > without using an add-in? > > Bob H.
