Teun,
That was it. Frustrating to have to copy the default project to all users'
individual machines instead of just pointing all to the network server. But
this works!
Thanks very much.
Sam Bixler
Eli Lilly and Company, Indianapolis
"Teun Ham (IV9)" wrote in
message news:416407bd$1_2@newsprd01...
> As far as I know, it only works when using the Default.ivb location
> (C:\Program Files\Autodesk\Inventor 9\Bin\Macros\Default.ivb)
> I have heard that others also encountered problem when trying to use an
IVB
> that is located at a network.
> It should work when using the Default.ivb location...
> "Sam Bixler" wrote in message
> news:41640517_2@newsprd01...
> > Teun,
> > Thanks for your help. Unfortunately, this fails at step 4) with the
> > following errors:
> > Autodesk Inventor 9: Failed to open document.
> > Microsoft Visual Basic: Automation error Unspecified Error
> > The References dialog box shows ApplicationProject as available for
> > selection, and when I pick it, the location shown is correct. But it
> always
> > gives the above errors when I click OK. Does it matter that the
> Default.ivb
> > is located on the network?
> > This reference step is what I was missing, but I'm unable to get it
> > accomplished.
> > Sam Bixler
> > message news:4163faf2_3@newsprd01...
> > > Yes, this is possible:
> > > 1) Copy/Paste this sub in your Default IVB:
> > > Sub RunThisMacro()
> > > MsgBox "This works!"
> > > End Sub
> > > 2) Open a part/assembly
> > > 3) Open the VBA Editor
> > > 4) Create a reference to the ApplicationProject (Tools-->Reference)
> > > 5) Copy/Paste this into the DocumentProject of your part/assembly
> > > Sub AutoSaveStartsDefaultIVBMacro()
> > > ApplicationProject.Module1.RunThisMacro
> > > End Sub
> > > If you now save your part/assembly the messagebox will appear!
> > > news:4163ef1d$1_1@newsprd01...
> > > > I'd like to remove a bunch of code from my part and assembly
templates
> > to
> > > > the application VBA project. But I can't figure out how to call a
> > > procedure
> > > > in the application project from a procedure in a document project.
> Any
> > > > help?
> > > > This code is to automate our part/assembly numbering, and it has
> worked
> > > well
> > > > in the templates, running as AutoNew macros. But I want to get rid
of
> > the
> > > > duplicate code in several templates and have each template do
nothing
> > but
> > > > call the common code from the application project.
> > > > Sam Bixler
