Adding custom iProperties to idw ussing the vb.net Inventor API (Code included)
I know how to create custom iproperties for either iparts and assemblies, but cant create any for my idw drawings? I cant get the same thing done for the iproperties of idw files? Th code I have sofar is as follows
        Dim invApp As Inventor.Application
        invApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
        Dim Doc As Inventor.Document
        Doc = invApp.ActiveDocument
        UpdateCustomiProperty(Doc, "MYPROPERTY", textbox1.text)
        Doc.Update()
    Private Sub UpdateCustomiProperty(ByRef Doc As Inventor.Document, ByRef PropertyName As String, ByRef PropertyValue As Object)
        ' Get the custom property set.
        Dim customPropSet As Inventor.PropertySet
        customPropSet = Doc.PropertySets.Item("Inventor User Defined Properties")
        ' Get the existing property, if it exists.
        Dim prop As Inventor.Property = Nothing
        Dim propExists As Boolean = True
        Try
            prop = customPropSet.Item(PropertyName)
        Catch ex As Exception
            propExists = False
        End Try
        ' Check to see if the property was successfully obtained.
        If Not propExists Then
            ' Failed to get the existing property so create a new one.
            prop = customPropSet.Add(PropertyValue, PropertyName)
        Else
            ' Change the value of the existing property.
            prop.Value = PropertyValue
        End If
    End Sub
The error i get is the following screenshot...
 Now Im just confused 😞
mabey one of you guys can help me out?
nmunro
If you look at the bottom of your screen capture, the Autos window shows the current value of variables at the current statement. It clearly shows that your document reference (Doc) is Nothing. Your code is somehow not capturing the document object. Once you fix this it should work.
https://c3mcad.com
thats whats confusing me it normally just captures the document...?
NachoShaw
Hi
First things first, i would most definately change this
to this
Dim Doc As Inventor.DrawingDocument = invApp.ActiveDocument
Once this is done, you will be able to see what property options are available from a DrawingDocument as oppose to a generic Document.
Also,
Are you running the function from the drawing environment or are you running it from an assembly to pass iProperties to a drawing? If so, the Assembly would be the Active Sheet and you would need to declare the Drawing document separately as a DrawingDocument
Cheers
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
