Populate a multi-value parameter using iLogic with a For/For Each statement
sergio_duran
sergio_duran
Hi Everyone,
This API code allows me to fill out a list with multiple values
SyntaxEditor Code Snippet
' Create lists of numbers and letters' by using array initializers.
Dim numbers() As Integer = {1, 4, 7}Dim letters() As String = {"a", "b", "c"}
' Iterate through the list by using nested loops.
For Each Number As Integer In numbers
    For Each letter As String In letters
        Debug.Write(Number.ToString & letter & " ")
    Next
Next
Debug.WriteLine("")
'Output: 1a 1b 1c 4a 4b 4c 7a 7b 7c
I want to do something similar in iLogic, how can I do it? (please see the attached image)
I want to create a list and fill out the multi-value parameter using a For / For each statement.
MultiValue.SetList("d0", 0.5, 0.75, 1.0, 1.25)
I want to enter 0.5, 0.75, 1.0 and 1.25 from a previously list created.
Thanks!
Owner2229
Hi, try this. Red Is what I've added / changed:
Dim MyArrayList As New ArrayList
' Iterate through the list by using nested loops For Each Number As Integer In numbers For Each letter As String In letters MyArrayList.add(Number & letter) Next Next MultiValue.List("d0") = MyArrayList
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
sergio_duran
Thanks Mike! You're the best!
I've just learn two new things. One of them was the iLogic snippet that is there under the Parameter snippets (6th snippet Set List from ArrayList)
Owner2229
As always, you're welcomed Smiley Happy
Mike
