ADDING COMPONENT MULTIPLE TIMES IN MORE THAN 3 SITOATIONS
kothaananthasai0811
kothaananthasai0811
ThisAssembly.BeginManage
Dim OMEGA_PROFILE_ASSY_W As ManagedComponentOccurrence
Dim i As Integer
Dim panelCount As Integer = CInt(NUMBER_OF_PANELS_ON_BTM)
Select Case DRAIN
Case "DRAIN_BEFORE_BLOWER", "DRAIN_AFTER_BLOWER", "DRAIN_BEFORE_AND_AFTER_BLOWER"
For i = 1 To panelCount
OMEGA_PROFILE_ASSY_W = Components.Add("OMEGA_PROFILE_ASSY_W:" & i, "OMEGA_PROFILE_ASSY_W.iam")
If OMEGA_PROFILE_ASSY_W IsNot Nothing Then
' Use OMEGA_PROFILE_ASSY_W directly without casting
Constraints.AddMate("Mate:" & (i + 16), OMEGA_PROFILE_ASSY_W, "XZ Plane", "", "YZ Plane")
Constraints.AddMate("Mate:" & (i + 17), "", "XZ Plane", {"OMEGA_PROFILE_ASSY_W:" & i, "OMEGA_PROFILE_W:1"}, "Face5")
Constraints.AddFlush("Flush:" & (i + 1), "", "XY Plane", OMEGA_PROFILE_ASSY_W, "YZ Plane", -(B_PANEL_L_1 + B_PANEL_L_10 + B_PANEL_L_3 + DRAIN_1 + 42.5 mm + DRAIN_2 + 15))
Next
Case "NO_DRAIN"
Constraints.AddFlush("Flush:" & (i + 1), "", "XY Plane", OMEGA_PROFILE_ASSY_W, "YZ Plane", -(B_PANEL_L_1 + B_PANEL_L_10 + B_PANEL_L_3 + 30 mm + 42.5 mm + 45))
Next
End Select
ThisAssembly.EndManage
ERROR IM GETTING IN THIS
Error on line 13 in rule: Rule4, in document: BTM_OMEGA_PROFILES.iam
"Mate:18" was already managed by an earlier statement in unnamed group.
JMGunnar
you code generate  mate name
@kothaananthasai0811
    "Mate:" & (i + 17)  = "Mate:18"
Next
     "Mate:" & (i + 17) = "Mate:18 "
Next
Best Regards Johan G
